Advice Needed Best 4K receiver
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Good morning
What is the best 4K receiver with powerful tuner
Using octagon sx88+ SE but I think the tuner is not that powerful
Is there any receiver which can connect to the mobile via an APP and show all the menu for dish settings.
Any Enigma2 receiver can work with mobile apps.
Not sure what you mean by "powerful tuner" as they are not measured in horsepower...
Good morning
From personal tests, the best one I have used for tuner sensitivity is the Octagon SF8008.
It is E2 so can be controlled by the WebIf in a browser.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Powerful I mean sensitive which can boost the weak signal and make it stronger
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
While using webif is it possible to change between satellites and TPS
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I tried sf8008 but it was freezing and picture quality was not very good.
There was also a delay when changing channels.
I prefer a receiver which can connect to the App.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
The box cannot improve a bad signal or a bad picture.
I wonder if the WebIF on the SX88 4K does what Gladstones is wanting :confused
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I had a experience in the past you get solid lock on weak tp by better/ sensitive tuner
I think you'll struggle to find a receiver that is significantly more sensitive than the SX88+.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Let’s see Research is on.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
whats 4k available fta , mostly demos :N
future proof ? 10 years ? maybe nothing else
or get one from sky & pay @ watch 4k (rip off)
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Equally, it could go the way of 3D, down the tubes
Manikm909
Small'ish Dish Man
Kent, UK
you cant go wrong with octagon sf8008 - tuner more sensitive than edision mio 4k
for any E2 receiver you can download and use SATFINDER app configured for E2 ip address - i use it up ladder to peak signal in real time over wifi
3D goes down the tubes every ten years or so, then makes a worthy reappearance.
upgrading to higher resolution often fixes things.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
how do you compare sx88se tuner with sf8008 tuner
Manikm909
Small'ish Dish Man
Kent, UK
Well not sure about sensitivity but the sx88 cannot lock sub 1250 symbol rates. The sf8008 in contrast can lock very low SRs on manual scan just not blind scan
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Anybody have a experience of 88 and 8008 tuner sensitivity thanks
