Express AM6 at 53.0°E Afghanistan Ku band Beam
ZazaiSat
Gothenburg
Gothenburg
Ok and if anybody else knows any site for a good ku band dish from which I can buy then please let me know, would be thankful for it
ZazaiSat
Gothenburg
Gothenburg
I don't think you can order new, it just cost too much or it's mainly good for C-band
Check online sites where people sell used stuff
Or keep eyes open when you travel. If you see one go and ask if it's for sale
How much could be the new one? And if U find any 3m dish or a bit larger for ku band then please let me know
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
The solution is C band in Sweden?
Several thousand euros. And you need to be absolutely sure you have permission from the local authorities to install such a dish.
ZazaiSat
Gothenburg
Gothenburg
I’m living in a big villa/bungalow with big clear garden and it’s fine here to install it at my house and why would the local authorities have to say anything in this?
Because there tends to be rules and regulations that cover the erection of buildings and permanent structures. Get in touch with whoever is in charge of planning at your local government offices and seek advice before you spend a penny.
Because they can.
For example here in the UK there are VERY strict planning laws regarding dish sizes & amounts of reception dishes / antennas that can be erected on properties. If they deem your dish breaks planning regulations not only can they demand its removed asap but if you refuse they have the right to send workmen onto your property to do the work - then bill you for the work!
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Flat spectrum in southwest Germany with 2.2m on 11592 V...
Ok and can u recommend any sites from where I can order a good 3m or lagger then 3m for this sat, for ku band ?
Before you order anything you need to find out what the signal levels are in Sweden - and I tell you now they will be terrible. There is no point you spending over Eu4000 on a 3 m dish then finding you need a 5m dish. Or bigger.
If there is absolutely nothing showing on a spectrum with a 2.2m dish in Germany chances are you are going to have to go MUCH bigger to have any hope at all, especially with that 9/10 fec.
ZazaiSat
Gothenburg
Gothenburg
Ok sir and @ocean04 got the signal with a 3m in Finland
What ocean4 got is useful but there is absolutely no guarantee you will get similar results with the same sized dish. He is hundreds of km away from you, and results can vary greatly over just a a few km.
