Sebastianbird
- Ku
- Rincón, Puerto Rico
I recently learned Dreambox DM500s is finicky about peripheral devices attached such as lnbs. Can someone forward a LNB that works best with Dreambox DM500s?
That rings a bell, LNB compatibility was something to do with the internal components.I recently learned Dreambox DM500s is finicky about peripheral devices attached such as lnbs. Can someone forward a LNB that works best with Dreambox DM500s?
www.satellites.co.uk
The channel list updated corresponds to current satellites in the sky and I may use individual dish and lnbs or just lnbs on one pan or splitters.Is the app is some kind of augmented reality app? While they can give an idea of where the satellite is in the sky, they shouldn't be totally relied upon. When you say one receiver has been updated do you mean it has a channel list containing the Galaxy 19 channels? If you can select one of these channels and then adjust the dish the picture should appear when it is correctly aligned.
LNB settings should be universal 9750/10600 22KHz auto or on. How do you plan on getting the single output LNB to feed three receivers?
As many people will confirm, you cannot use simple "splitters" on satellite feeds.The channel list updated corresponds to current satellites in the sky and I may use individual dish and lnbs or just lnbs on one pan or splitters.
No; currently, the dish which shares a space is only for a single position. I cannot tweak the position. So, I tried to work with what I had. Now I am obtaining a motorized dish to optimize signal use. I anticipate better results.Have you tried various channels to see if you are pointing at the wrong satellite? It will have to be a DVB-S MPEG2 SD channel for it to work.
Splitters don't work with satellite.
You will struggle to setup a motor if you are unable to locate a satellite with your existing fixed dish.No; currently, the dish which shares a space is only for a single position. I cannot tweak the position. So, I tried to work with what I had. Now I am obtaining a motorized dish to optimize signal use. I anticipate better results.
However, I have questions about the the motor’s tube. Do I use circle round or oval egg shape round?
how you obtaining motorized dish?No; currently, the dish which shares a space is only for a single position. I cannot tweak the position. So, I tried to work with what I had. Now I am obtaining a motorized dish to optimize signal use. I anticipate better results.
More information needed.
What system are you using, receiver, dish etc ?
What satellite & channels are you trying to view ?
I am pointing to 10E Eutelsat Satellite and still receive a strong Signal 100% but the quality is still 63% - weak. Help.
