OCTAGON SF8008 E2 4K UHD
There is the existing signal strength set-up in the motor menu section, that works well, but I will have a go tonight.
i dont update my E2 image very often - im of the opnion if it aint broke, dont fix it.
yes, i know you can backup to image, but it always turns into a major setup operation for me, mainly cos i record of my LAN and i have some timers which are a pain to resetup.
I have both style of remote. Neither has an option button
Which screen are we starting from?
I updated the 8008 here last night but couldn't see any additional features in the menus, I've not actually checked what happens with the 'press 1000' code, will try tonight.
That 'info, info, option' works on the 'user define' software. I use the sx88 remote to access it as that has the option button
I appear to have inadvertently removed the 'Define' image from the list and so I will re-load tonight and check.
I wonder what this does, has anyone tried it? :)
Not having this RX, I tried something similar with the SX88 which has just received a f/w update.
All it actually does is to provide a magnified view of the SS &SQ bar graphs almost directly from the main programme-viewing screen, but you can then push the Option button again to take you directly to the Antenna Settings menu - but then you lose the magnified view at that point!:rolleyes:
It might have been of a bit more use if the magnified view SS/SQ was available in those Antenna Settings menus, but I hardly see the point of it in the main programme-viewing menus where it is now!:rolleyes:
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10550 30-04-2021
OCTAGON:
SF8008m Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
Changes:
1. WiFi Treiber aktualisiert.
1. WiFi driver update.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10550 OK
Online Aktualisierung:
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10550 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10550 OK
SW Offline - USB .mupg:
Recovery Bootmenu MMC (E2) SF8008 & SF8008m:
OCTAGON GERMANY SUPPORT
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10551 16-05-2021
OCTAGON:
SF8008m Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
Changes:
1. Satellit 27.5W Programmsuchlauf Funktion eingebaut.
2. Amazon Prime Video, Youtube Kids und TRT Cocuk app`s ins Hauptmenü eingebaut.
3. Multi-Mac Funktion verbessert.
4. Favoriten und Nicht zu ende Funktionen ins Stalker Vod eingebaut.
1. Added 27.5W Satellite Channel Scan - Search.
2. Amazon Prime Video, YouTube Kids and TRT Cocuk app`s added in Main Menu.
3. Fixed Multi-Mac function issue.
4. Added Favorites and Not Ended function to Stalker Vod.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10551 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10551 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10551 OK
I'm wanting to flash my SF8008 with OpenATV 6.3 but the zip file doesn't contain a ‘usb_update.bin’ file, just the Octagon folder? I'm concerned about bricking the box if I try flashing without it. Can anyone advise please?
6.3 is no longer updated
If your on the new recovery then you just use network multiboot image upgrade and select a slot
Just remember to back up
Hi Guys, been reading this Thread today with great interest. Some of you are very knowledgeable.
I have a request for the experts. Am using the SF8008 Twin with 500GB HDD connected via Blue USB and a 256 SDCard at Rear.
Am looking for ALL the older versions of the openATV 6.3 "recovery.emmc" and "mmc" version from July and August 2020.
Thanks, a hint in the right direction would be really apprec.
regards.Andrew
The nightly updates - as far as I recall - do not include the update.bin file requested, but I will try in about an hour with the receiver I have here.
