Would it please be possible to obtain a copy of this recording?
Does anyone know how to convert 4:2:2 to 4:2:0 so it is playable again on Enigma2 settopbox?
I tried converting the .ts file with VLC to .ts Video - H.264 + MP3 (TS) with deinterlacing filter on.
The result is from a 50 GB file makes a 2.3 GB file with poor video quality and the audiotracks are switched.
When I try to play it on a settopbox it stops after a few seconds.
Handbrake converts it to MKV, but I'd rather want the standard TS-format what Enigma2 uses.
Furthermore I don't know if Handbrake can convert it and what options I should enable.
ffmpeg -i <4:2:2 file name.ts> -c:v libx264 -pix_fmt yuv420p -profile:v high -level:v 4.1 -preset slow -flags +ildct+ilme -crf 18 -c:a aac -b:a 128k <output-file-name.ts>
Wasn't there a plugin with Open ATV that would work playing it through KODI??Does anyone know how to convert 4:2:2 to 4:2:0 so it is playable again on Enigma2 settopbox?
Thank you for the detailed explanation. I could try ffmpeg of course.
About the audio, VLC shows this:
Stream 1 is the correct audio, Stream 2 just plays a message and Stream 3 is static, Google learnt me that 302M Audio contains information for 7.1 audio? Would be awesome if that can be used for coverting to 5.1 AC3 audio f.e.
ffmpeg -non_pcm_mode copy -i <video file.ts> -map 0:3 -c:a pcm_s24le -f s24le <output audio filename.wav>
ffmpeg -i <output audio filename.wav>
ffmpeg -non_pcm_mode copy -i <video file.ts> -map 0:3 -c:a pcm_s16le -f s16le <output audio filename.wav>
ffmpeg -i <output audio filename.wav> -ar 48k -c:a ac3 -b:a 448k <ac3 output file.ac3>
Is it being recorded and broadcast in UHD anywhere?stiil not yet uhd feed
