satellite hobby
- FreesatfromSky
Freesat [Humax HDR 1000S]
Fta(9E/13E/19E/28E) [Fixed Triax TD88]
1.1M motorised satellite dish [unbranded]
- UK
Hi everyone,hope everyone is well
I have the Tehnisat Technibox UHD S,which is a twin tuner pvr,since last year.
Tuner 1 is connected to a 80cm Triax with multi lnb bracket:13E/19E/28E/9E via a 8 output diseqc switch, however the 9E lnb is currently disconnected and 7E (on a zone 1 Sky minidish),is connected to the same 8 diseqc switch.
Tuner 2 is connected to a 13E/19E monoblock on a zone 2 minidish
However,in recent months,the second tuner has been showing no signal.
I assumed the dish had moved,so realigned,yet the second tuner continued to show no signal,checked with another cable,connected to tv with satellite connection (Ferguson F2220S),and the signal was fine.
Yesterday,I replaced the original twin shotgun cable,which was connected to the second tuner,in case it had become damaged,though it was not visible or in case of water ingress,there was slight discolouration on,one of the connections,though both connections have rubber boots fitted
Again the second tuner is showing no signal,yet when i connect it to the Ferguson tv,it is working fine.
Should I reset the receiver,to factory settings and start again?
The online manual to the Technisat can be found here:
https://www.technisat.com/assets/medias/docus/123/BDA_KURZ_TECHNIBOX_UHD_S_DE_EN.pdf
English instructions page 81 onwards
Thanks for any input.
