- UK
That does sound like software only, so the first patch should fix the gremlins.Does the same thing on a Ka scan when trying to delete channels.
Re: Ka LO input - it will not save a 'Single User' LO setting and scan, but when using the 'Dual User' LO setting box and set the LO to be the same in both boxes, it will save it and scan. If you use the 'Dual User' LO option and only put the right LO i one of the boxes only, and leave the other box setting to all '0' it will not scan. There is no option to choose H /V/L/R polarity setting - you have to use the 'lnb voltage' setting of either 13v or 18v to get you the right on-screen ch information.
The initial fag packet GT Media was a nightmare as well, sorted some five months later.
The only hardware issue I came across was the tuner input falling off (though you can't bolt a TV via SCART to it
