Technomate 5402 M4
Seconded :Y ... iv'e got a few suggestions to put forward that are more 'enthusiast' related but i'll let them carry on with the more 'Domestic' niggles first.
** I ran a crude tuner/receiver performance test the other night between a few different receivers - TM Mk4 / TBS6983 / StarSat SR-X7 Extreme / GT Media V9 / GTMedia V8X / Freesat V7 HD and the TM Mk4 had slightly the edge of maintaining lock before picture break-up.
A future Manic firmware update might bring in 4k resolution. :)
.... Meant to say also - I receive Sportsmax from 55.5West ok - do you need some info off of it
SportsMax sometimes shows West Indies cricket but it is on late at night into the early hours for the current series of WI vs AUS T20 matches.
It is not until they get to the ODI matches that the hours get more sociable.
Forum member "manic01" has achieved miracles in getting Technomate to be pro-active with after market support for the TM-5402 (M4).
His efforts have resulted in the receiver being transformed from a possible candidate as a door stop at 1st launch into what appears to be a potentially good receiver.
Although I have not yet purchased a TM-5402 (M4), I am grateful for the effort put in by "manic01".
There are probably quite a few owners of the receiver who are of a similar view?
Would you please be able to scan 40.5W using the Ocatgon SF8008 using an E2 image such as OpenVIX or OpenATV rather than the Define software?
I am not sure if the Define software utilises the same blind scan plugin as the full blown E2 images so there might be a difference in the number of channels received?
If the TM-5402 (M4) can outperform an SF8008 runnning a full E2 image in terms of number of channels scanned it is definitely one for the feed men to consider.
Also, there are quite a few T2-M1 frequencies in C-Band on 40.5W, can the TM-5402 (M4) lock and resolve these?
Same channel count fot TV.20210710_152056.jpg 210 in total but that included radio
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
Any thing else needs sending to TM give me a shout
Have asked for
7 day epg repeatedly
Correct stb serial number for server renewal
Ability to use diseqc switch same as other 5402 models to allow fixed and motorised combination, atm has to be OFF/Diseqc or Usals, cannot combine
Channel editor
Certain card/cams need sorting
Blind scan Range
Epg to scroll in blocks of ten
IPTV access
Map recall button on RC
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Have asked for
Channel editor
Blind scan Range
IPTV access
What is server renewal?
Have asked for
Channel editor
Blind scan Range
IPTV access
Here's a few
Ability or choice to select either H or V for a scan. H/V/L/R would be even better.
Ability or choice to enter a specific scan frequency range.
Ability to show an indication of encryption type tag in the received scanned channels.
**Important to me - When using my Norsat C-band lnb with LO of 5750, the receiver will scan the normal range of 3.400 to 4.200 GHz but it wont scan the extended range of 4.500 to 4.800GHz which it is capable of doing.
Give the choice to switch off 'Password'-Input Pin' demand.
Grateful for your work with this rx :-clap
Have asked for
Channel editor
Blind scan Range
IPTV access
8k upscaling :p
manic01
GB
Here's a few
Passed on.
Answer from barney115
Answer is goto Menu>Password setting and put all OFF
Passed on.
... You beauty :Y
4Himdj
1.2 Laminas Dish
Rome
hello
is it possible to compare octagon sf8008 and tm5402M4 on very fringe signal please?
I mean pixellated trasponder on 8008 can be watched without issues on 5402?
thank you very much
best regards
Manikm909
Small'ish Dish Man
Kent, UK
its a shame they didnt include 4k, in a modern receiver
does the blind scan compare to the 5302 and 5502 models?
Manikm909
Small'ish Dish Man
Kent, UK
You stupid boy...
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
I manage to pick one of these on ebay.
Blind scan is good and fast, but you can't put a freq range in yet so it's a bit silly.
M4 plays 16APSK feeds now which is a bonus and improvement :)
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Anyone knows the answer thanks
Renewal of some functionality that provides desirable juice.
The desirable juice usually runs dry after an allocated time period has lapsed and then a payment is required to get it to flow again.
To the best of my knowledge, the desirable juice functionality is beyond the scope of discussion allowed on this forum.
Staff Note
Quite so. That is just about as far as the string stretches - no further questions m'lud.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Thank you
