Advice Needed Freeview box recommendations please
excollier
Bikes, Booze, Rock & Blues
TD 64 and Humax Foxsat HDR with Raydon's custom firmware
County Donegal - furthest outpost of the EUSSR
A FreeView box with Catchup would usually be called a YouView box, the name of which has a large number of products on Amazon.
The price is proportional to the T1 / T2 tuner system and the upscaling that can be sent to the screen.
I would start with something basic that costs virtually nothing and see if they get on with it, since the top of the range ones can be quite overwhelming, as some clients of mine have discovered.
A FreeView box with Catchup would usually be called a YouView box, ...
No, they are different. As well as catch-up YouView can also offer paid for services when they are supplied from your ISP (BT and TalkTalk I believe).
To be truthful there's precious little difference if you buy your own YouView box outright though.
The Humax DTR and Panasonic Smart series boxes can be bought without any need to go to/through a service provider.
(similar spec throughout, the former has the subsidy advantage and the logo)
mikejp1
none
sussex
My ISP, Plusnet, is 'dropping' its YouView service. Is there any way (other than BT/TT) to get pay channels at a reasonable price? I have tried to find a way to get in touch with YouView but it is impossible.
I would like to retain the YouView box and its functions like programme guide/record etc
It depends on what extra channels you're after. Now TV has a few packages but the sports channels aren't cheap.
Manikm909
Small'ish Dish Man
Kent, UK
if u can get a Humax HDR-1100S for around £100 second hand (no longer made) - they are great boxes, they are official Freeview, and support an app for recording etc remotely
Errm, no. That's a Freesat box.
OP wants pukka Freeview (DTT).
Manikm909
Small'ish Dish Man
Kent, UK
Oh yeah . Sorry chaps .
mikejp1
none
sussex
Back again - once I lose the YouView service with PN I will lose the YouView Programme Guide. Is there any way I can replace it so I can select 'later' recordings? The YouView offers up to 7 days look-ahead and is really useful.
The standard Freeview EPG is at least 7 days so that shouldn't be an issue.
mikejp1
none
sussex
ozumo - being delightfully ignorant of how these systems work, would I need to do 'anything' once YouView 'drops out' to enable the Freeview PG on the box?
(Excuse the ignorance and howl with laughter if you wish :-) )
YouView is just Freeview & catchup services, plus the option for pay content from your ISP. The box should still work exactly as before but without the pay channels :)
mikejp1
none
sussex
Thanks - my 'sub' ends next month so we shall see how it goes.
This might affect many more people in the future unless YouView provides a valid IP address with the services their boxes can 'tunnel' to.
It will be interesting to get responses from others experiencing a similar loss of service whilst their box is under the guarantee period.
The box will continue to work, but access to the catchup services (and I suppose the schedules) will not
All the services offered on a standard off the shelf YouView box will continue to work, including the EPG, BBC iplayer, ITV Hub, My5 etc.
Plusnet offers (offered) two options within the package, the '+' recording version is/was a Humax DTR model, as far as I know same as the one as on the BT circuit.
Edit - the non recording one is also a Humax - DB-T2200 or similar
