About scanning on TBS 6522 and T2 MI
fabulas
Vu+ solo 2
Catania
Hi, I decided to buy the TBS 6522, I wanted to ask you something .. I read around that a TBS 6522 owner says that the scans are bad and that most of the blocks that are normally there with the TBS 6903 are not shown on Crazyscan ... who has both 6522 and 6903 can tell me if you confirm this? who uses the 6522 to scan can you tell me how is it please? is there a preferred tool for this scan card that is better than another or are they all the same?
One last thing, does the TBS 6522 support the T2 MI which should be the future of multistream? I ask this because I have read that it does not work with the "T2 MII-tool", so I wanted to understand if maybe it does not work with this tool but it hooks these frequencies anyway ... someone has tried using the Smart DVB program which has the settings for the T2 mii if it locks the frequencies on the 5 ° W? Thanks to who will answer me ...:)
halliwell
galaxy
Ger
Hello,
I'm not the blindscan guy. (I'm not using the 6522 for blindscan)
But I can guarantee that locking Multistream Transponders with VDR or MumuDVB is possble!
Best
fabulas
Vu+ solo 2
Catania
Hello,
Best
if you have not used the 6522 for the scan you cannot tell me if the scan is good or not ... I know it is possible to see multistreams but I asked if it is possible to see T2 MI signals with this TBS 6522.
deeptho
Europe
T2MI means "DVB T stream embedded in a a regular transport stream". So from the point of view of hardware, "does it support t2mi?"
is an irrelevant question. The question should rather be: does my card support the tye of transport stream which contains the t2mi stream
that I am interested in. Some t2mi streams are embedded in a multistream transponder, but not all of them.
A more important question is: which software can support T2MI? The answer to that question is independent
of the card.
I do not have a TBS6522 either, so I cannot comment on most of your questions either.
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
Both cards support DVB-S2 multistreams (windows, linux). Most popular linux and windows software support multistream tuning.
T2-MI support related to software only.
fabulas
Vu+ solo 2
Catania
Meanwhile, thanks for the answer...
so if I understand correctly the T2 MI support depends on the software used and not on the model of the TBS card ... even if from what I understand not all the T2 MI software are compatible with all TBS cards, for example I read that the T2 MI-tool does not work with the TBS 6522 while with the 6903 and 6925 it works...
can you please tell me which software to use for the T2 MI with the TBS 6522?
regarding the other question I asked in the first post, about the quality of the scan with the TBS 6522 can someone who owns this card answer me please? Thanks
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
SmartDVB, AltDVB, astra-sm
no, I use windows 10 ... can you tell me which software to use for T2 MI with 6522?
Here's a T2-MI test with the 6522 card with AltDVB. Works great with this player.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Very interesting that alt dvb decodes T2 MI streams didn't know this ! Anyone using the 6522 with Windows 11 btw ?
