- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
If you're talking about 12639H my guess is interference from 12643V. As you're using a monoblock the skew is likely to be incorrect for the Eutelsat skew offset, therefore the transponder with a close frequency on the opposite polarity is interfering.
