Octagon SF8008 & 4:2:2
Offtensive
Midlands
A0560CAF-CC4C-4E5C-A6E0-659EB3DEFC9B.jpegSo I tried the following today
Octagon SF 8008 to Qled Q8 2018 TV: Just sound no pic
Octagon to NVidia Shield 2019 Pro via Kodi: Nothing, no pic no sound
Octagon to NVidia Shield via VLC: Blocky picture, pic above
Direct satellite cable to TV - my cable is too short and doesn’t reach. I’ll try and extend the wire and retry
View attachment 139740So I tried the following today
Does the TV have a web browser, if so you could try the receiver's WebIF. Or put a recording from the box onto an SD card or USB stick (or DNLA) and try it on the TV's media player. If that doesn't work I think the HEVC file can be extracted from a recorded .ts file (I've done it with H264 but not sure about HEVC).
maxi_power
120cm motorised dishes
PT
Octagon SF 8008 to PC with MPC-HC player, works just fine...
Manikm909
Small'ish Dish Man
Kent, UK
well i can confirm the KODI PVR CLIENT method, doesn't work on Octagon SF8008 on this channel - just a green scrambled garbage screen.
at least we know now.
Manikm909
Small'ish Dish Man
Kent, UK
recording a file (octagaon SF8008), and playing it on VLC on pc works fine also....see attached for video info
EDIT - also playing the network stream (found via E2 WEBIF) direct via VLC works no problem:
Offtensive
Midlands
It should have one, I’ll give that a go tomorrow.
I’m surprised that I didn’t even get sound with kodi but vlc gave video on the same device. All 4:2:0 channels worked on kodi, although they didn’t appear as crisp as they do on the receiver.
Offtensive
Midlands
I tried the TV browser this morning, no luck whatsoever. However the browser didn't work for other channels too. I'll give the usb recording a go later.
Just tried using Safari on a MacBook Pro 2015. That only gave me sound, no picture.
VLC works very well on the same machine. I watched it for about two minute, there was one occasion when the picture did go blocky for a split second, but that possibly could be due to network issues? MacBook is connected via Wifi to the router
On VLC on an iPhone XS Max. It worked ok ish, not great though. When I tried to cast to the shield, I couldn't get that working.
Offtensive
Midlands
Did you get any sound on kodi?
maxi_power
PT
Some posts from "GTMedia GTCombo 4:2:2 receiver" could be changed for this topic...
Offtensive
Midlands
In VLC, is there anyway to play the current channel from the receiver without typing/copying the full address?
astra19
98cm motorised technomate. 50e to 34.5w
Europe
When did Al Forat go 4:2:2?
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
On my system using OpenWebif click the little tv and VLC opens and plays.Screenshot 2021-12-07 at 17-27-27 Zgemma H9 S - OpenWebif.png
Offtensive
Midlands
Works perfectly on Kodi running on an Xbox One X :)
Can anyone recommend further/higher bandwidth feeds to try?
There are a bunch of 4:2:2 feeds on 7.0E tonight for the Champions League matches but all biss encrypted. They are higher bit rate than Al Forat.
ac1139
120 cm PF, 180 cm offset.
100 km north of Vienna
actual feed
Eutelsat 10A (10.0°E)
Frequency: 11561 - Pol: V - SR: 7200 - FEC: -
Category: Sport - Volley
Transmitted in: MPEG-4 4:2:2
Info: W:Liberec-Novara
Offtensive
Midlands
I tried 11081 H 9873 on 7e - Ajax vs Sporting Lisbon
Not as good as the other one. It was suffering from a fair bit of motion blur at first. Turning post processing on and then back off again made it better. There is some like ghosting now, not sure if that’s the right word.
Having let it run now for a few minutes it is watchable, but not perfect.
ac1139
Here is an index of an active feeds. Football feeds with symbol rates 9 874 and 14 400 are almost always 4:2:2
Satelliweb Live Feeds
