OCTAGON SF8008 E2 4K UHD
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Offtensive
Midlands
UHF 55 is the weaker transponder according to the below.
I had managed to scan it but it was breaking up. I haven’t checked it on my tv. I used the Xbox tuner on a raspberry pi last year and from what I can remember I think all channels worked. I’ll be able to try the tuner on the Xbox in a couple of days once I get it back.
I normally use ABM for bouquets but it has the incorrect frequency for all the channels on UHF 43.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Ukfree is woefully out if date but the Freeview site confirms it is lower power via their detailed checker. I speculate the Xbox tuner has a higher lock threshold, I thought I read it was 20dB but I may be wrong. I'm not too fussed anyway just wondering if I could get it working. Com 7 is being given the chop half way through 2022 as far as we know. So one less thing to worry about.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Offtensive
Midlands
Just done a rescan, UHF 55 coming in fine and working
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Mine works great on a standard TV, anyway I thought I would try one more time and to my amazement it scanned in. No breakup, it would be nice to have a signal scale. But can't complain.
Having trouble getting ABM setup now :D
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I have downloaded the autobouquetsmaker in Plugins > System Plugins in openatv 6.4 but this isn't showing thereafter in the plugins menu? Do I need anything else to get ABM running?
Offtensive
Midlands
Menu > Setup > Reception > ABM
Configure first
Then start scan
You may have to reboot to see this
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I needs some picons, only comes up ones for Australia in plugins in openatv?
Offtensive
Midlands
Is there no option to download any from the plug in browser?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Only the Australia ones, I'm using Menu > Plugins > Download Plugins > Picons. Is this where you mean?
Offtensive
Midlands
Yes, I don’t bother using picons, so I’m not too sure on then. They may be included with a skin - again not certain on that.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
From what I have been told the xbox tuner is not able to return snr values etc.
I installed enigma2-plugin-drivers-dvb-usb-dib0700_1.0-r1_all and was able to do a scan with that.
I'm not sure this is true, I remembered I previously used Update DVB on linux and it does show dB and BER, so these are being read (mine isn't setup completely properly but did what I needed it to do). Maybe a case of finding the right image and or programmer that can get these values read.
Offtensive
Midlands
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10569 14-11-2021
OCTAGON:
SF8008M Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
Changes:
1. Multibitrate HLS Play Funktion eingebaut.
2. Stalker Browser api aktualisiert.
3. Chronium Browser und Kodi Zertikate aktualisiert.
4. Xtream M3u und Stalker verbessert.
5. DVB-S2 Tuner CH. Zap Geschwindigkeit verbessert.
6. Internet CH. Zap Geschwindigkeit verbessert.
7. Picons aktualisiert wie Astra19 Hotbird13 Türksat42.
1. Multibitrate HLS Play function added.
2. Updated Stalker Browser api.
3. Chronium Browser and Kodi certificat. upgrade.
4. Xtream M3u and Stalker improved.
5. DVB-S2 Tuner CH. Zap speed improved.
6. Internet CH. Zap speed improved.
7. Picons upgrade like Astra19 Hotbird13 Türksat42.
1. Multibitrate HLS Play özelligi eklendi.
2. Stalker Browser api güncellendi.
3. Chronium Browser ve Kodi zertifikalari güncellendi.
4. Xtream M3u ve Stalker uygulamalari iyilestirildi.
5. DVB-S2 Tuner Kanal gecis hizi artirildi.
6. Internet IPTV Kanal gecis hizi artirildi.
7. Astra19 Hotbird13 ve Türksat42 Picon`lar güncellendi.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10569.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10569.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10569'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10569 OK
Online Aktualisierung:
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10569 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10569 OK
SW Offline - USB .mupg:
Recovery Bootmenu MMC (E2) SF8008 & SF8008m:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
Do you only need to do this if you use the Octagon OS? Or should you do it if you’re using Open ATV/Vix etc too?
Jjust upgraded to the 22nd Dec image (ATV 7.0). A nice touch is the ability to load all previous network/satellite/plugin/custom data without having to do it all again.
MCelliotG
Thessaloniki, Greece
Isn't openATV 7.0 showing the channel frequency wrong though? It adds a 0.5 to every channel.
Perhaps, though this is the 8008 from TJ, running the main TV as opposed to DXing.
The second box runs PureE2 which has a number of anomalies, including the inability to send the DiSEqC command to move the dish unless I am in installation mode, so it's no good for the family.
cokeaddict
Vu+ Ultimo4K, Uno4K SE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE v1 & v2, Solo2, Ultimo, Uno, Duo, Motorised CM 1.2m dish, Hybrid Titanium Smart Lnb with CM feedhorn and a Zone2 minidish with Inverto Unicable II
53°E - 45°W
Incase anyone here isn't aware.
There is now an official OpenBh 5.0 image for the Octagon SF8008
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Anyone have problem with define OS on UKTV channels (Dave, Drama, Yesterday) at 28.2e for DVB subtitles?
Latest define OS the DVB subtitles flash for about a tenth of a second?
