Newbie Here can I transfer recordings from my old humax box to my new freesat recordable 4k tv box?
Dale Aitken
I'm not sure. I use a satellite dish to receive freesat/tv. I use a laptop and router.
Unfortunately the answer is no.
What make/model of old Humax box ?
Manikm909
Small'ish Dish Man
Kent, UK
u can probably transfer them from old STB to USB Stick \ HDD, and play them on your new STB- theres also a slim chance you might be able to download them to your new STB also
Last time I checked, the USB port on the 4K boxes is for software updates only.
Al Adham
Amman
1.8m Jonsa PFA, Inverto Black Pro C120, Inverto Feedhorn, Mutant HD51 4K Receiver,
Amman - Jordan
My Mut@nt HD51 4K can play videos from any USB stick/HDD just fine, so it's best to give it a try.
The Mutant is not a Freesat box, but a generic receiver.
Freesat boxes have restrictions that cannot be overcome easily. Not being able to transfer recordings is one of them.
FYI, Freesat is a closed EPG system, on a restricted selection of approved receivers, available in the UK and, at it's simplest, provides high-level features (ie simplicity of use) for non-subscription viewers similar to what eg Sky does for the rich. FTA Channels only, though, of course.
