Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
lol i wondered that too but still cleaned it up.
just painted dish (with a roller @moonbase )
not sure i'll bother with two coats, unsure
Once it is up they can hear how good some of the music channels are from satellite reception.My paintwork is very patchy for that camouflage effect but the neighbours still moan.
Just tell them it's your mini dish, the big one is coming soonMy paintwork is very patchy for that camouflage effect but the neighbours still moan.
Get a room.its been emotional....
today was a good day!
dish up - @RimaNTSS arms installed - and first attempt at alignment.
due to never have setting up a CM1.8 before, and due to the amazing adjustment capablities, including the adjustsable LNB holder, i am finding it difficult to align - at least i found 1W- although, sadly, not as stong a signal as my 1.2 - i know the LNB isn't facing the sweetspot.
still lots of work to do on alignment.
It can be at any position. You have length-adjustable feedarms, so by adjusting the length you can place LNB in any position. The main goal is to co-locate LNB's phase center with antenna's focal point. And that point is located 1830mm from the top point of the working area of the dish and 1080mm from the lowest point.should it be at lowest limit \ highest...?
