I had (have??) a similar issue with the Gibby (it's a heavy bugger!) on the Dark Motor, the total mass of which caused the 2" scaffold pole to bend slightly forward!
Given I had no chance of "upgrading" the pole to something thicker, I installed 3 steel "construction" braces for the pole:
- one fits between the pole and the side of the garage about 5ft away, and because it's actually slightly longer than that distance then it's in compression and is slightly bent due to the force applied by the combined dish/motor/pole combo!
- the other two fit laterally and rearwards between the pole and the (neighbours'!) fence posts about 4ft either side of, and 18" behind, it.
- All 3 braces are secured to the pole with car exhaust clamps
The net effect was to "push/pull" the pole back up much closer to the vertical, and that seems to work "quite well" for pretty accurate tracking from 40W to 53E (just) - although I know that CH has made a couple of somewhat distainfull comments about the Heath-Robinson nature of the arrangement!
