SUPERYACHT TV on 52°E in Paris ?
zorrin
Specialised contributor
CM 120 Ku 52°E to 45°O
CM 120 Ku 50°E to 45°O
CM 120 Ku SDR 25.8°E
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
GTMedia V8 Nova, V8X, V8 UHD 4K, V9 Prime
Edision Piccollo
france
Hi everyone,
For the moment I don't have a dish with a possible view of 52°E
I would like to receive SUPERYACHT TV near Paris.
what is the minimum size of the antenna or is it impossible?
That's what I'm doing right now.
But I want to create a DVBT channel and the streaming server of this channel regularly crashes the connections...
Did you receive the channel on the old frequency before it changed ?
(SYtv is available on Apple TV from memory)
No i started with the streaming
I only have a 1m20 Channel Master, to small...
Perhaps it was my receiver but when I could receive it from 52°E (or one of the nearby birds?) it was always glitching & had stuttering video so maybe no surprise the web stream isn't stable.
Is your SDR spectrum scanner up and running? See if you have a tickle on the spectrum, it only needs 1dB in theory to lock.
I found another solution.
They launched an Android TV app and it seems stable.
But it's a different stream from the WEB version. The logo has black writing.
I wonder if it's another version on the sat.
Hi @ozumo,
I'm waiting for sunny days
The weather is not pleasant to play outside with an SDR and a laptop...
I see the needle of my satellite pointer move a little in the satellite area but no lock on my digital signal finder.
Superyacht was an easy catch off 52E for a while when it was on one of the European beams. Interesting to watch for a while but a bit unless you had a few million to spaff on a luxury yacht a bit tedious after a while.
Yes it is very specialized but I like beautiful boats. The application is very stable under Android and the image and sound quality after the modulator is very good. I would have preferred a satellite source, but that's good enough.
