Edision OS Mio+ 4K UHD Query
stephan94
Bavaria
I Use TNAP4.2 an American image made especially for Edision MIO4K (+) and for the blindscan
TNAP is a good image for an FTA receiver. It is fast, has a good blind scan and is actively supported by "el bandido"
However, it can be a little tricky to setup for things like oscam as some of the relevant functionality has been removed.
If I remember correctly, I had to FTP some files, possibly library files into the E2 system to get oscam to work?
stephan94
Bavaria
TNAP is a good image for an FTA receiver. It is fast, has a good blind scan and is actively supported.
I only use my receiver for the Dx, so everything else is no problem for me
and the less extra programs that take up space and CPU, the more satisfied I am
Offtensive
Midlands
I assume the tuners in single and twin SF8008 are the same as that in the SX88+/4k, or are the latter “better”?
Manikm909
Small'ish Dish Man
Kent, UK
UPDATE!!
SO it IS the image....THIS is really going to mess with my loyalties - ive ALWAYS used OPENVIX....but now i dont think i will be so loyal!
I just booted up OPENATV and it found the multistream channels no problem!!! (and was quicker!!!)
8 TPs with OpenVIX and 14 with OpenATV
Pics attached.
