Anyone know if this feedhorn is any good for a large offset dish 1.5
jambon550192
Paphos cyprus
1m orbit h2h manhatton plaza cm1.8 inverto quad with cm feedhorn at 7w,tm 6900 super hdfixed 1.5 prime focus on 16e with tring diseqc x4 at 7w v/h 13e 19.2e 28.2e with 3 quad smart titanium gold 0.1 lnbs ,TM-3000d 2.5 precision at 25.5e
kent
I've found this prodelin oversized feedhorn for an offset dish I have a 1.5 I use a standerd 40mm quad lmb and just looking for something that would perform better .
Trust
Nijmegen Netherlands
You forgot to show a picture or type nr
RimaNTSS
Some SAT-related hardware.
N-E from Riga
i have feed horen for prime focues build my self
Is the 1.5m dish prime focus?
jambon550192
Paphos cyprus
kent
sorry guys tried to post a pic and it won't let me I'll keep trying. Dish is like a channel mast off set 1.5.
jambon550192
Paphos cyprus
kent
jambon550192
Paphos cyprus
kent
1.8m antenna will, for sure, perform much better.
No.point dish Is over sized anyways its looking at 25.5e and I'm.in cyprus but for a 1.5 it should be better
RimaNTSS
N-E from Riga
nelson_b
Contributor
Hi - That feed is identical to the one on my Channel Master 2.4 dual reflector ...
jambon550192
Paphos cyprus
kent
RimaNTSS
N-E from Riga
jambon550192
Paphos cyprus
kent
jambon550192
Paphos cyprus
kent
Been trying for an hour to post a pic won't load
jambon550192
Paphos cyprus
kent
jambon550192
Paphos cyprus
kent
Got there in the end
nelson_b
Contributor
I have tried the 2.4 dual reflector feed on a regular 1.8 Channel master offset in the past..... but the result was that it was not as good as a normal channel master feed ....
RimaNTSS
N-E from Riga
@jambon550192 for sure the feedhorn you've shown earlier will work on this dish. But take in account you will need special flanged LNB to attach this feedhorn. But, at the end of the day, it might happen that performance of your system will not improve.
You better start by placing the existing LNB in perfect position. Also, check whether the mirror is not warped.
jambon550192
Paphos cyprus
kent
Yes I may purchase it and dust off.my c120 invacom see what happens. I do get very bad weather in the winter . I lost all.my bein channels this week due to a very bad rain and hail storm on my 2.5. At this I was very surprised but I supose you can't stop It no matter how big the dish.
jambon550192
Paphos cyprus
kent
This the same problem as I had ? Why is this?
