14w new Russian transponder
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Locked 11121 H 3589
11647 V 14181
on TM5402 M4 on Triax 110. Signal quality 98%.
SatSearcher
West Yorkshire
OK so tweaked the dish a little and managed to get lock on all 3, strange thing is to achieve this, had to nudge the dish to somewhere near 13.4W! The previously unlocked frequencies (11546 & 11564) now come in at around 9.2dB, while the 3rd on 11647 drops slightly from 14.7dB to 13.5dB. I thought maybe there's interference from 15W or 12.5W, but doesn't seem to be anything on those that would interfere. Very strange!
Could be interference from 15w as you say - even on my 2.2mtr tight beamwidth i was seeing signals from 15w, very low but still there. Smaller sized dishes with a broader beamwidth will suffer even more and probably have to compromise like you did by moving a tad either way of 14w
rodscha
I tried now around 7:30pm localtime,only got Al Manar(booming )
and the bootleg RT Deutsch ,which was made illegal recently,in poor shape(breaking picture just lockeable)
70% on the 3rd russian frequency 11646V 14182....but no lock!!!ggrrrr
Adam792
Cheltenham
11646V working here on a zone 2 Sky dish (~60cm) on a tripod. My Satlink meter reports an SNR of around 10dB.
No lock on the other two.
I speak no Russian, but Channel 1 is running what’s clearly a smear piece regarding Ukrainians being Nazis…
MCelliotG
Thessaloniki, Greece
Frankly, I'm quite surprised at Perviy and Match! being FTA! I'll have access to my satellite system next weekend, so I hope they'll not lock in Ghostcrypt like everywhere else...
New channels not working here on my multi-stream receivers shows a good signal but no tv here on 14°west o_O
Working here on a Primo, manual scan with MTS on :)
Adam792
Cheltenham
Something a little strange with these, Flysat reports them as being timezone +0 because they're the versions for DTT in Crimea. Sure enough, Perviy Kanal matches up with the International version on 13°E (13°E is around 10 seconds behind).
However the EPG seems to relate to what I assume is a far east region, it's showing the current on-air programmes on Perviy Kanal and Russia 1 as being things like "Dobroe Utro" (between 18:00 and 22:00 GMT), which means "good morning". This would be 6:00am-10:00am in the UTC+12 timezone in Kamchatka...
MCelliotG
So, apparently this MTS method leads people to believe that T2MI is multistream?
so,multistreams again I see T2MI=multistream...
T2MI is not multistream, neither is new. It looks like you haven't been paying that much attention in this forum's topics....
rodscha
so,a technisat digiplus UHD S should be able to deal with this T2MI
I just have a vocabulary problem ,not knowing exactly
HEVC,i know,is received by my receiver... how do I get T2MI?
MCelliotG
No, it won't. T2-MI is a special transmission, the channels are encapsulated. You need a receiver with more capabilities that can get these special transmissions. And this is why a good market research is crucial, otherwise you only get people complaining...
Os mio 4K, SF8008 and others among them can do both multistream and T2MI...
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
Can anyone get this working on Engima2?
Can I download a enigma 2 bouquet template for a AX51?
rodscha
@MCelliotG I found your tutorial,and I m reading it. Thank you !
SF8008 is on Amazon indeed at an acceptable price ,a big thank you!
So,I would use my double tuner on one side & an SF 8008 on the other to "play" with this system.
Get an additional dish. I see . Thank you for enlighting me.
Multistream,T2-MI,Hevc... any other I should add to my research?
zorrin
Specialised contributor
France
www.facebook.com
france
if you have to choose one between the Os mio 4K and the SF8008
which one would you take ?
stephan94
Bavaria
you can read here
, the advantages and disadvantages of the two receivers
are explained
Manikm909
Small'ish Dish Man
Kent, UK
Octagon has better tuner
MIO can do multistream on blindscan.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Can anyone get these new Russian 14° West channels working on Engima 2 ?
Im using a Mutant 51 DVB2X.
I can scan in only the radio channels. Radio CH50-CH59. I can lock the transponder no probs strong signal with a 60cm triax dish.
