local system user
- Mar 5, 2022
- Age
- 44
- Planning a setup
- Cambs
In my new home I have a single coaxial cable heading outside from the wall box where it meets coaxial cables running to TV/Radio sockets installed in all rooms. I am planning to install DAB, FM, DVB antennas using triplexer/combiner and satellite dish with two LNBs attached to splitter or diseqc switch. What I need is advise that equipment to use to make it working properly.
As a triplexer/combier I'd like to use for instance:
https://cpc.farnell.com/optima/114212/outdoor-fm-dabuhf-tv-triplexer/dp/AP03518
Then for satellite LNBs:
Twin 4-feed LNB for 9°E, 13°E, 19.2°E and 23.5°E for 80cm dish
+ another one to cover 28.2+28.5 positions.
What should I use to combine/sum the triplexer with satellite signal and be able to watch tv from two different satellite positions?
MFD 411 DiSEqC 4Sat+1Ter x1out ?
Also is it possible to cover 28.2 and 28.5 with single LNB converter assuming 80cm dish? I am aware about the 7 degree skew difference between 28.2 and 28.5.
What should I use in the cable box at home to distribute the signal?
Please take a look on the attached picture.
