Advice Needed Multiswitch for 3/4 LNB's
goral_
VU+
Manchester
Hi
I plan to use 3 LNB (may be leather 4 LNB's) wideband. And I looking for multiswitch.
Or can anyone know how to connect 3 Unicable LNB's to 2 receivers?
Terryl
Custom built PC
Here is a good start....
https://emp-centauri.cz/product-category/wiring-for-tv/multiswitches/3satellites/
Unicable solution, three DC pass 2 way splitters into two 4 way DiSEqC switches should do it.
Technisat do a 4 way Diseqc version that will take 4 quattro LNBs. I use one myself..
Might help the OP if you could give the model number &/or a link so that he could take a look for himself.
7mdish
Milan, Italy
Please note that goral_ mentioned unicable. If you must connect 3 or 4 unicable LNBs, I believe that the unique solution would be to install 3/4 quatro LNBs and use one Unicable/DCSS multiswitch with 4 INs and 2 OUTs (or more if more receivers must be connected).
The problem could be to install so much LNBs on a single dish because such products are bigger than common DCSS, 1 OUT LNBs. So a specific evaluation is needed.
No idea which multiswitch could be used, but surely EMP Centauri or Spaun are good manufacturers for such products.
