freesat list in .SDX
joesto2222
toshiba smart tv
wn8
hi to all
does anyone know where i can get the FREESAT tv list in a .SDX format please
thanks
joe
Is this for your Toshiba TV? Is there an option to do a network search?
7mdish
Milan, Italy
Which editor to open SDX setting files? Thanks
joesto2222
toshiba smart tv
wn8
thanks for the swift reply
my tv is toshiba
but when i do a network search there are channels missing
Which channels are missing?
This appears to be a channel editor for the .sdx file format
https://sourceforge.net/projects/novasatcodx/
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
There are very many versions of sdx files, be very lucky to find unpaid version of editor to suit most Tv/ stb
This thread has a member using the same editor on a Toshiba TV so there is hope:
manic01
GB
Good find, I suppose they have to work on something, as it works on a vestel tvs then Toshiba won't be a problem as it's basically same thing.
