Turksat new transponder 18739 L
Sat01Uk
SX88 4K
Penta 85cm
Technomate 2600 H2H
Black Inverto LNB
53E - 34.5W
East Anglia
Sorry if this is posted in the wrong place!
Does anyone know how to receive that transponder 18739 L? What kind of LNB is needed etc? am I right in thinking it is S band, can they pack more channels into one transponder using that frequency? What kind of sing all strength in east/south east UK? Thanks, all.
Its Ka band. Not S-band. Ka is split into about 4 frequency segments that need specific lnb's.
Some info on 42E here
Sat01Uk
SX88 4K
Penta 85cm
Technomate 2600 H2H
Black Inverto LNB
53E - 34.5W
East Anglia
thanks I’ll take a look ..
SimonE
Gloucestershire, UK
I bought an XMW R9216AF which I imported direct from South Korea. Its a linear LNB which is ideal for The Ka Band at 19E and I use a depolariser in its mouth for circular polarisation. It came with a feedhorn FD9000 which allows you to mount it in a clamp designed for Ku band [40mm]. I see from their website they do PLL LNBs now. [Mine is a DRO design] Ka-band LNB, Ku-band LNB, X-band LNB and C-band LNB - XMW .
That Ka 5 band 'Penta' pll model ..... hmmm, don't know if i dare enquire re: price Simon :D
SimonE
Gloucestershire, UK
John, I can only encourage you. From memory I think the DRO one was £300 or so. Let me know what they say! I presume we could still use the same feedhorn.
Probably but not 100% sure re: feedhorn - - i didn't open the pdf on it because i knew it must be in the few thousands to purchase so i thought i would struggle through with the various single band ones i already have :D
SimonE
Gloucestershire, UK
A new mux has appeared on 18709L 12500 2/3.
dreamsat
germany
here my update (a little bit of rain)
dreamsat
germany
18738 L with many programms
rodscha
Talking Turkey(lol) ,what about their new 30.9°East that started a year or so ago?
Still sleeping it seems..https://flysat.com/en/satellite/turksat-5a
Why would they keep such a big bird idle?
stephan94
Bavaria
with 1.80 everything also goes very well
