- Aug 10, 2008
- Romania
@deeptho,
The joy lasted only a moment with the last kernel installed(from @Llew), because although the settings in neumodvb remained the same, the cards were no longer connected.I tried another kernel version, but every time I install with the command "make allyesconfig", the resolution changes.In other words, if I have a normal resolution, devices not connected, and conversely, when your drivers are installed, the resolution is changed.
Of course it is annoying and time consuming to deal with each case individually,but please tell me how to install your drivers with your ./sh command from #214.So far I have not succeeded.
Of course I can install the drivers with the command from tbs,but then I can't use your blindscan,and so there's no point and charm in insisting.But I want to see how the cards behave in different environments,Windows and Linux.What's new in your version,say,with the 6903x card on Linux vs Windows.Can Linux better highlight the enormous hardware capabilities of stid135 that Windows cannot?The step you have now taken is just the beginning of a revitalization of this card(?) And I say it's worth a try.
