40.5°W SES 6
duck77
C Band / Ku Band 2.40 PF / Ku Band 0.85 dish for Hispasat
Vu+Duo 4k / Vu+ Zero 4k / Octagon 8008 / Octagon 8008 Mini / Tbs 5927
Satellite reception between 50.0E-99.2W
Azores
Good afternoon I did a satellite search ses 6 and I got this new frequency 11340 H 14397 3/4 enters 1 channel with the name Greenw Res encoded in biss I don't know if it's probably a feed.
Dggrr
VU + Zero, Triax TD88, Technomate TM2600 (Plus CM 1.2 in bits behind the shed)
SE
Thanks, was there but gone at 22:30 GMT
Satfaca
Melmac (46N, 14.5E)
Melmac
Satfaca
Melmac (46N, 14.5E)
Melmac
Major weather problems. :confused :)
1_0_1_2_1_1_C7B2C4C_0_0_0_20220311181145.jpg1_0_1_2_1_1_C7B2C4C_0_0_0_20220311180813.jpg1_0_1_2_1_1_C7B2C4C_0_0_0_20220311181042.jpg
1_0_1_2_1_1_C7B2C4C_0_0_0_20220311180852.jpg1_0_1_2_1_1_C7B2C4C_0_0_0_20220311181116.jpg1_0_1_2_1_1_C7B2C4C_0_0_0_20220311181020.jpg
Just checking this out here, Central UK .....
View attachment 141509View attachment 141510
This is another one that gives strange results on the GT Combo - if you open up the channel it displays as normal - change the 'Player' out of curiousity and it displays as if it's a 4:2:2 tx and shows a very low fps , shows a 4:2:2 'movie camera' icon in the info section but no 4:2:2 indication text at the side of the AVC line
Whilst were still on 40.5West, can anybody make anything more of this Ku signal captured on a TBS6903 PC card, 2.2 PF non-optomised antenna, PotPlayer or SMPlayer to view.
** Ignore the ref to 14.0West on the EBSPro grab.
Satfaca
Melmac (46N, 14.5E)
Melmac
Nope, it's a continous ACM stream, still no goodie known to me how to handle it...
Encrypted in BISS today
stephan94
Bavaria
Now active again
40.5W_The signal on both Atlantic beams in my area :)
40.5 W. Up again - BISS.
stephan94
Bavaria
by 11136 V 30000 3/4 32APSK is a Continous feed to" see"
sky sport Italia
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
very weak here southeast ireland,stephen on my mabo 1.85m offset and IBU
butchyboy
ireland
i take it theres no ku 24/7 channel on 40.5w
astra19
98cm motorised technomate. 50e to 34.5w
Europe
sky sport Italia
The first image has the logo for NPO1, the Dutch broadcaster. Do you know if that was a different channel or just Sky Sports taking some video for something like an interview?
stephan94
Bavaria
You are right, I just looked again, it's written in Flemish, they only take extracts from sky sport TS-1-39-54-074.jpg
7mdish
Milan, Italy
Which threshold is required to lock such signal? 32APSK 3/4.....
