40.5°W SES 6
astra19
98cm motorised technomate. 50e to 34.5w
Europe
It could be a feed for the Caribbean. The Dutch public broadcasters are available on the islands there that are part of the Dutch Kingdom.
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
i saw that RTL 7 and some other private channels also are within this stream. I've been looking for a long time for a way to decode the picture properly... It'ts like a multistream "next gen"... Maybe in a couple of years we will find consumer boxes capable of receiving this sort of stream.
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
i can sniff that, but cannot lock it.
same here get a good 68-69% on signal but when i do tp scan it does not find the signal soley because it keeps dropping from 68-69% to zero
Manikm909
Small'ish Dish Man
Kent, UK
same as much - shoots up around 86% then drops to 16-18% - nothing locks
hey ho.
astra19
Europe
Ah yes I think those feeds have appeared elsewhere before too. The mystery deepens as the commercial channels aren't available outside of the Netherlands proper. We don't really know why. I've tried searching Sat4All but haven't found anything relevant.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Here is the corresponding thread;
Other feeds that use this method in this thread;
EDIT----
Here is the corresponding thread on Sat4all that i've started back in time (for what it's worth)
7mdish
Milan, Italy
So a very big dish is needed I assume.....
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
stephan94
Bavaria
with the continuous streams it changes continuously
it can be 8PSK and suddenly 16APSK.
or else these are the current receivers (also the Sat cards)
who can't quite figure out what the FEC is.
7mdish
Milan, Italy
It could be interesting to know which professional receivers must be used for that.
Professional boxes on the market are not so much: Ericson (ex Tandberg, do not remember latest brand), Ateme, Sapec, Harmonic..... I do not believe they use custom-made receivers...... What do you think?
Not really, I use a 1.50m antenna and receive both Atlantic beams from the eastern part of Europe. Vertical polarization can also be received with a 1.10 cm antenna in my area.
Here is my signal atm and the transponders I locked with this antenna.
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
My Signal with Laminas AS2700 and Octagon SF8008
