deeptho
- Apr 7, 2006
- Age
- 57
- Wavefrontier T90, Laminas 120cm, 2 other dishes; tbs 5927, tbs6904, tbs6909x, tbs6903x, tbs5990, tbs6981,tbs5927
- Europe
I do not know if all of this is correct, but there seems to be confusion. I do not think satesco actually INSTALLED the programs, Instead he compiled it and ran it from the source directory (as recommended). It seems to have run properly, but then he deleted it and in the mean time, for some reason some other changes to his setup prevent recompilation.Thanks for wanting to help me. I tried to do what it says on the link you gave me. It didn't work. I also tried the Recover Deleted Files app, but without success. I'm not sure if it's still possible to recover the working app.
To cleanly install the app, I also tried to delete any files left in neumoDVB from the previous installation. Unfortunately, the same errors are still occurring as before(u32 and u8).
I hope I'm not wrong, but the structure you're talking about has to do with how the frontends are registered in the previous installation. These adapters cannot be ordered otherwise by a new building. Although it shouldn't be a problem, I think I did the driver installation after neumoDVB(?). Because of this, the application didn't know how to choose the correct adapter. Plus, only some of my tuners had the driver that Deeptho designed.
There must be another method of installation despite the persistence of these errors. I hope Deeptho will step in with a solution.
I hope I don't start all over again, with installing blindscan drivers and then neumodvb
I performed an installation from scratch of the drivers and the application on a clean (new ) ubuntu system and
-except for the incorrect/incomplete dependency list - the instructions I provided on github lead to a fully working system.
No compilation errors, no screen resolution problems. etc. Of course all bets are off if you start mixing older and newer versions of python, libraries ... or if some other required software is not installed.
In the mean time I also did some test like that for fedora36. There have been a few changes in fedora since fedora34, so
again the dependency list needs to be updates, a small change to the source code was needed and some FALSE compiler warning is emitted, but apart from that, I also ended up with a working system.
Soon I will upload a new version, which has some other bugs fixed as well.
Hopefully soon I can also provide a "direct download' I am considering "AppImage" for that. The main downside is that
such downloads are huge. Theoretically they should work on all linux systems. That still leaves the problem of driver
installation, which is sometimes difficult (but I repeat: the instructions on github at deeptho/linux_media simply work
on both ubuntu and fedora - at least on a clean system).
