Satspot
- Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
- Ireland
What are you trying to achieve. Put the Combo in server mode and serve to a client. If that’s the case just get the Combo to create a playlist and have your client play it in real time.Is there an equivalent of the WebIf on an E2 receiver for an android receiver such as the GTMedia Combo?
For example, is there an android app that can be loaded onto a GTMedia Combo that allows it to be fully controlled by a PC in a similar manner to what the WebIf does for an E2 receiver?
The WebIf for E2 on a PC accesses the E2 receiver using a web browser via the LAN IP of the E2 receiver.
As the GTMedia Combo has its own LAN IP, an app on the GTMedia Combo could host connectivity and allow control from a PC, if such an app exists?
What kind of control do you need over the Combo. Sounds more like SSH to me. In that case install SSHelper app.
Of course there’s the GT Share app I’ve mentioned here a thousand times. Just install it on the Combo so the Combo can act like a server/client all in one box.
Maybe you could be a bit more specific on what you are trying to achieve. You’ll find most of anything you’re looking for in the App Store with a simple search and of course the best place for this query is the GT Media forum where Tom.W will be only too glad to point you in the right direction.
