AV-comm constructions
MrDish1
Delta Star
Qth:Aalten
I'm looking for examples of adjustable constructions with an AV-Com
Mvg
Please explain what an "adjustable construction" is. Do you mean an LNB changer or something else?
MrDish1
Delta Star
Qth:Aalten
Hallo ozumo,
No not a: LNB Changer.
But to run the C-band LNB with a servo engine.
And to let the AV-Commun shift due to; The depth in the scaling.
Prime focus or offset ?
MrDish1
Delta Star
Qth:Aalten
kan alle bij.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
@MrDish1 can you provide some pictures of equipment, such as AV-com and antenna you are going to marry? Or that was only a theoretical question?
MrDish1
Delta Star
Qth:Aalten
That AV-com is from Wim (Trust) ,and the dish is the 1.84 from Chappie (Chaparral)
RimaNTSS
N-E from Riga
MrDish1
Delta Star
Qth:Aalten
Found wot at this forum from Dreamsat.
Mvg
RimaNTSS
N-E from Riga
I still do not understand where is the problem.... Just take your Av-Com and install it on your dish. Just make sure the phase center of the LNB (Av-Com) is co-located with the antenna's focal point. Very simple.
MrDish1
Delta Star
Qth:Aalten
Am I talking about a problem.
I do not think so.
RimaNTSS
N-E from Riga
So, where is the problem? Can you show it?
MrDish1
Delta Star
Qth:Aalten
Want to make it so that I can fine-tune the dish in the hobby room downstairs.
I already have qwer and dreamsat as an example of what they have made.
RimaNTSS
N-E from Riga
Aw, I see, question is solved and thread can be closed. Even though we miss some real pictures :cool:
dreamsat
germany
please
RimaNTSS
N-E from Riga
Thanks! Now it is clear. :)
Does the above solution fix the scaling, or just polarity/skew settings ?
MrDish1
Delta Star
Qth:Aalten
That`s rotate the lnb is clear.
but does is go Up and down in the scalaring that AV-Com.
that is wot i olso wonne now.
Thank you channel hopper.
MrDish1
Delta Star
Qth:Aalten
It goes up and down, only with which engine I don't know (yet)
