What satellite are these ?
rs100
CM 1.0 DISH
Which satellites are these this afternoon while looking for extreme west c band satellites as I have a clear view right over to 72w as being in wales on the side of a hill I tried some c/ Ku-Band satellites and found a few data transponders , Any idea what satellites they are ? Ignore that it says 55w on the screen btw the photo (satellite) with more transponders is it to the right of the pic of the satellite with 3 transponders listed
Thanks what about the other one ,?
Check Lyngsat and Flysat websites for frequency listings that match up, that is what I did.
Note that for data frequencies, unless the Lyngsat or Flysat frequency entry has been updated recently the SR might have changed.
frankviana
Satellites/tv
Brazil
Any idea what these KU data stream are what are they for ?
Few years ago, I did tests with Skygrabber and download some pictures, videos, etc.
I don't remember that transponder, but I think is active too.
frankviana
Satellites/tv
Brazil
I need to know what kind off lnb ka lock this transponder
thx.
thx.
You need a Ka-Band B LNB for 19896 MHz.
Something with similar L.O. to the LNB in the picture I have attached below should be OK.
Note that the frequency of 19896 is with circular polarity so you will need either a dielectric plate or some type of polariser in the feed assembly.
rs100
CM 1.0 DISH
I need one of those lnbs
