I had that problem. I bought a Viark 4K and never looked back as the Tecky was buggy from the start.How can I solve my problem of the blind scan freezes?
What version of firmware are you using. What satellite are you tuning to when your receiver freezes up.How can I solve my problem of the blind scan freezes?
Hope that worked. If not let us know.Thank you Satspot,appreciated.
Is this freeze only happening on 68.5w. Are you using the M4 with your other dishes when testing too.Satspot I did the download but did not solve the blindscan problem on my fixed dish.The receiver freezes when using the satellite 68.5 West (fixed) via a diseqc switch ,using a polarmount.I have no problem when doing a blindscan on my two other moving dishes.(also via a diseqc switch.)
I am not sure what is causing the problem when blind scanning the fixed dish.
This freeze happens on both my dishes with separate diseqc switches to which the fixed dish on 68.5east is connected.Is this freeze only happening on 68.5w. Are you using the M4 with your other dishes when testing too.
Unfortunately I can’t steer my dish to 68.5e to help you with the test. Where in the world are you located. Are you using C band or KU band or both. Make sure the LNB is correctly configured to match whatever band you are using.This freeze happens on both my dishes with separate diseqc switches to which the fixed dish on 68.5east is connected.
Dish1 lnb 1 and 3
Dish 2 lnb 2
Both my dishes are polar mount. I dont have a freeze problem when doing a blind scan on other satellites.
Glad to hear that. A factory reset and a fresh reflashing of the firmware usually resolves the majority of issues on the M4.Satspot I have resolved my problem by doing another download.I think the USB memory stick I used was faulty.Your assistance and advice is appreciated.
