Help Needed to get my Octagon SF8008 Set up to move to different satellites when selected
danaddison
100cm Sat dish on Superior Dark Motor Metal Gear DiSEqC 1.2-1.3 USALS GotoX, connected to ground pole
This is the motor i have and its also set to 0 and 53 degrees yes
its the settings on sf8008 i need help with nothing else once i got the settings correct then it should move the motor and dish!!
EnoSat
enosat.euweb.cz
Slovakia
info about motor in user profile
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
EnoSat
enosat.euweb.cz
Slovakia
Because then users don't have to ask what device you're using
PS: Satfinder moved dish left or right ?
etc. direction Astra2
Mickha
North West
Actually it does help to have information regarding your satellite dish, motor, and general location.
Are you using USALS, or Diseqc 1.2, to drive your satellite dish?
danaddison
Install some motor settings
how?
ok and no it isnt and i dont know why because i can get it to move when connected to my pc satellite card using dvbdream etc so it should work on the sf8008 aswell, well trying USALS @Mickha but for some reason whatever settings i change nothing happens
stel883_
Vátika, Greece
Either from plugins in receiver or through software on pc.
danaddison
stel883_
Vátika, Greece
It will give you ready made channel lists, on each satellite.
danaddison
thanks
so this is on my sf8008 on astra 28.2e using my sky sat dish connected to my sf8008 and everything is set up correctly asits not got motor attached and as u can see its memory index is 28 goto is 0.28.2 East with signal locked etc
so if my s8008 can pick this up on my sky satellite dish and not my 100cm sat dish something is wrong, but my 100cm dish is aligned correctly etc as i can lock onto feeds no problem any ideas why my 100cm sat dish wont work like my sky one does?
EnoSat
enosat.euweb.cz
Slovakia
If you use any of these cards you can try the spectrum after turning the dish with SF8008
danaddison
i have 2 satellite tv cards in my pc 1 i have coxal cable plugged into which is connected to a splitter then the other cable plugged into sf8008 so im splitting the signal 2 ways
danaddison
Update: dish is now moving with sf8008 but not getting signal from any satellites in positioner setup any ideas plz??
stel883_
Vátika, Greece
Choose a working frequency first not a random one.
Don't use a splitter, connect directly to the motor/LNB.
thanks ill try that now, and thanks for the screenshots, my screenshots have a different long and lat on it because i dont want people knowing my exact location, but when im not posting on here i correct them to my long and lat :) btw my default satelliteim positioned to is 0.8w
i have done all thatView attachment 143327
this is what im getting now
What you haven't done is provide the image detail of the receiver, but unless it has issues it wouldn't help you currently.
I would suggest you play with it overnight , possibly take the receiver and monitor out to the dish and see if it moves at all when you press the right commands.
If you are installing the system for somebody else then they will be as annoyed as you are after seven hours.
Open another thread tomorrow.
