Adam792
- 90cm Corab dish, TM-2300 motor, TBS6903X, TBS5930 Lite, Octagon SF8008 mini
- Cheltenham
You've done well to receive that in amongst the much more local BBC R2 transmitters. I quite often catch SpE stations below 88.0mhz where there's less competition but you have done well.There's been more sporadic E activity over the past few days, including this visitor from the Azores that I was very pleased to receive for the first time this year, and at the best strength I've ever had. It was in and out for around an hour at lunchtime on Tuesday.
Nice and easy to ID with the help of the "ACORES" service in parallel on 30°W 12519V, which as far as I know is actually the input feed to the FM transmitter.
I use the dxmaps.com website where you can check what others have heard. I wonder what aerial you use?Luckily here the Oxford transmitter which uses 89.5 for BBC Radio 2 is blocked by the hills to my East, so the frequency is relatively clear. It's there, but very low strength in the background, so a fair strength E skip signal like this one easily takes over!
It was interesting conditions at the time, 89.5 was the only signal received at all. There's another transmitter on São Miguel island which carries RTP Antena 3 on 87.7 (amongst other stations/frequencies), but there was no sign of that at all.
