Paksat 1R 38E
Different LNB, now two Gardiners on OMT, another mux locking in.. Screenshot_20220729-190349.webpScreenshot_20220729-190450.webp
If I get time today I hope to carry out some fine tuning to see if I can improve signal levels and lock a few more frequencies.
Looking at the list of unlocked frequencies there might only be three or four where I have any chance, the others seem to be no hopers.
Before moving on to some fine tuning I have uploaded a couple of screen grabs from the last two frequencies I locked from the baseline configuration of the dish
The updated list and screen captures are below.
Frequencies locked to date from baseline configuration.
01. 3717V, SR12000 (Dunya)
02. 3770V, SR7700 (City)
03. 3777V, SR2600 (PTV feed)
04. 3799V, SR5500 (SAB TV)
05. 3813V, SR16855 (Geo TV)
06. 3838V, SR4800 (Express)
07. 3846V, SR6600 (Starlite)
08. 3852V, SR3250 (ARUJ)
09. 3856V, SR2590 (PTV Bolan)
10. 3952V, SR2969 (Madani)
11. 3985V, 1600 (Time News)
12. 4004V, SR15560 (PTV)
13. 4023V, SR5700 (92 News)
14. 4029H, SR3600 (SAMAA)
15. 4038H, SR6151 (GNN)
16. 4081V, SR3254 (Atv Pakistan)
17. 4085V, SR3463 (GTV)
18. 4090V, SR2035 (Dawn News)
19. 4093V, SR2400 (Paigham)
20. 4101V, SR2800 (Roze)
21. 4101H, SR4340 (K21)
22. 4120V, SR2490 (TV2DAY)
23. 4125V, SR6400 (Atv) - new upload
24. 4131V, SR4166 (A Sports)
25. 4141V, SR3333 (Fast Sports) - new upload
26. 4174V, SR3148 (AUR Life)
27. 4185V, SR1444 (Venus HD)
38.0E_20220730_4125V_SR6400_Avt.jpg 38.0E_20220729_4141V_SR3333_FastSports.jpg
That,s an impressive list @moonbase -
Somewhat puzzled by the recent results from this 38 E sat, i swung the 3.m dish round to have a look here.
It seems that things have changed massively from my reception point of view ... earlier this year i was able to blind scan around 90 -100 channels on average from this sat with the 3m dish, and struggled with the one transponder i was most interested in .... just before i moved the dish round to the western satellites - a month or so ago i noticed that my troublesome transponder - 3837 H 6500 was regularly holding a good signal , around 1db over lock (constant)... . but i did not bother to look at other transponders.
A blind scan yesterday and this morning with the 3m. now only reveals 25 - 30 channels ... and the previously troublesome transponder being the strongest at over 11.0 db
DSC04354-Optimized.JPG ... i now only get a handful of transponders and a couple of those are borderline, it seems the north south divide on this sat has increased overall :-(
I will monitor for a while and make a list of the ones i,m getting - and the d.b. levels from them.
Agreed, these seems to have been quite a few changes to the channel line ups and signal levels.
Oddly, at 8.0dB I am 1.4dB below a lock for your "troublesome" transponder from my supposedly favourable UK location, whereas you are 1.8dB over the lock level for 3834H, SR6500.
My first fine tune experiment today resulted in a fine mess.
I adjusted the scalar position along the feed barrel from 30mm along the barrel to 0mm on the barrel (flush with the feed rim aperture)
Result - loss of 22 of the 27 frequencies previously locked !!
It is not a disaster and loss of frequencies with tweaking is to be expected. I will try a few more scalar locations at this specific focal distance to see how things pan out.
It does illustrate how fickle C-Band reception can be on these quirky satellites such as 38.0 East.
I adjusted the scalar position along the feed barrel from 30mm along the barrel to 0mm on the barrel (flush with the rim aperture)
Too true MB - to get the absolute max knat's Knacker performance re: the scalar positioning on my 2.2 Elite/Precision it was down to adjusting 1mm at a time i kid you not - and then checking also accurate distance measurements from the outer edge of the scalar to the dish edge in at least four different positions .
** Not forgot your other request btw - multi tasking here at the moment
Documenting things is not one of my stronger points .... but here is what i get from this sat on the two large dishes ...... on a drizzly morning here in the North West .
3.0 M dish 2.4 M dish
04. 3799V, SR5500 (SAB TV) ....................... 8.8 db locked ...................... 5.7 db locked
05. 3813V, SR16855 (Geo TV) ..................... 6.1 db locked 4.3 db no lock
08. 3852V, SR3250 (ARUJ) ....................... 7.9 db locked 3.4 db no lock
12. 4004V, SR15560 (PTV) ....................... 7.7 db locked 2.5 db no lock
13. 4023V, SR5700 (92 News) ...................... 6.6 db locked 3.5 db no lock
15. 4038H, SR6151 (GNN) ...................... 11.1 db locked ........................ 7.7 db locked
26. 4174V, SR3148 (AUR Life) ..................... 6.7 db locked 4.3 db no lock
3759 H 1003 Suno (radio) ...................... 10.9 db locked ............................. 7.7 db locked
3837 H 6500 8XM / Jalwa ...................... 11.2 db locked 6.3 db no lock
Change of LNB again, twin Sat Maximum cheapo from Aliexpress yeilds the best results so far.. Opp in the Midlands.. Screenshot_20220731-234644.webp
Change of LNB again, twin Sat Maximum cheapo from Aliexpress yeilds the best results so far.. Opp in the Midlands.. View attachment 144249
Nice. As an experiment, when you get chance, lob one of your Norsat pll on your Vertical port - i'll explain later
Ah ha..I should have said. The OMT is off in favour of this cheapo dual output LNBF from Aliexpress..
Ah ha .. Ok, no worries
Today's offering is fairly paltry, just two new frequencies locked.
The newbies are a result of the first stages of scalar tweaking, no changes yet to the feed rim aperture distance with respect to the dish.
The updated list and screen shots of the two new frequencies locked are below.
Frequencies locked to date from baseline configuration supplemented with a couple of scalar tweaks.
11. 3979V, SR3650 (Public News) - new upload (slight pixelation on this one)
12. 3985V, 1600 (Time News)
13. 4004V, SR15560 (PTV)
14. 4023V, SR5700 (92 News)
15. 4029H, SR3600 (SAMAA)
16. 4038H, SR6151 (GNN)
17. 4081V, SR3254 (Atv Pakistan)
18. 4085V, SR3463 (GTV)
19. 4090V, SR2035 (Dawn News)
20. 4093V, SR2400 (Paigham)
21. 4101V, SR2800 (Roze)
22. 4101H, SR4340 (K21)
23. 4120V, SR2490 (TV2DAY)
24. 4125V, SR6400 (Atv)
25. 4131V, SR4166 (A Sports)
26. 4141V, SR3333 (Fast Sports)
27. 4174V, SR3148 (AUR Life)
28. 4181V, SR5000 (Neo News) - new upload
29. 4185V, SR1444 (Venus HD)
38.0E_20220801_3979V_SR3650_PublicNews.jpg 38.0E_20220731_4181V_SR5000_NeoNews.jpg
Today's offering is miserly, just one new frequency locked.
No further scalar tweaking for this one, just signal level evolution over the day, with generally higher signal levels in the evening.
The updated list and screen shot of the new frequency locked are below.
02. 3754V, SR7500 (VU TV Network) - new upload (locked with Dr HD F15 receiver)
03. 3770V, SR7700 (City)
04. 3777V, SR2600 (PTV feed)
05. 3799V, SR5500 (SAB TV)
06. 3813V, SR16855 (Geo TV)
07. 3838V, SR4800 (Express)
08. 3846V, SR6600 (Starlite)
09. 3852V, SR3250 (ARUJ)
10. 3856V, SR2590 (PTV Bolan)
11. 3952V, SR2969 (Madani)
12. 3979V, SR3650 (Public News)
13. 3985V, 1600 (Time News)
14. 4004V, SR15560 (PTV)
15. 4023V, SR5700 (92 News)
16. 4029H, SR3600 (SAMAA)
17. 4038H, SR6151 (GNN)
18. 4081V, SR3254 (Atv Pakistan)
19. 4085V, SR3463 (GTV)
20. 4090V, SR2035 (Dawn News)
21. 4093V, SR2400 (Paigham)
22. 4101V, SR2800 (Roze)
23. 4101H, SR4340 (K21)
24. 4120V, SR2490 (TV2DAY)
25. 4125V, SR6400 (Atv)
26. 4131V, SR4166 (A Sports)
27. 4141V, SR3333 (Fast Sports)
28. 4174V, SR3148 (AUR Life)
29. 4181V, SR5000 (Neo News)
30. 4185V, SR1444 (Venus HD)
Attached below are a couple of TS Analyser pictures for a pair of frequencies I found in a blind scan of 38.0 East.
One of them is with modulation of 32APSK, the other is reported to have modulation of QPSK-S2, neither are listed on Lyngsat or Flysat.
They are probably data transponders of some type?
I have not added them to the list, these boys are more for the wavy line men than the picture men.
38.0E_20220802_4000H_SR2200_QPSK-S2.jpg 38.0E_20220802_4069V_SR1000_32APSK.jpg
Another paltry offering today, just one new frequency locked.
Again, no further scalar tweaking for this one, just a PTV feed which popped up that I had not previously scanned.
13. 3985V, SR1600 (Time News)
14. 3991V, SR2600 (PTV News Feed) - new upload
15. 4004V, SR15560 (PTV)
16. 4023V, SR5700 (92 News)
17. 4029H, SR3600 (SAMAA)
18. 4038H, SR6151 (GNN)
19. 4081V, SR3254 (Atv Pakistan)
20. 4085V, SR3463 (GTV)
21. 4090V, SR2035 (Dawn News)
22. 4093V, SR2400 (Paigham)
23. 4101V, SR2800 (Roze)
24. 4101H, SR4340 (K21)
25. 4120V, SR2490 (TV2DAY)
26. 4125V, SR6400 (Atv)
27. 4131V, SR4166 (A Sports)
28. 4141V, SR3333 (Fast Sports)
29. 4174V, SR3148 (AUR Life)
30. 4181V, SR5000 (Neo News)
31. 4185V, SR1444 (Venus HD)
View attachment 144272 View attachment 144273
Might have a look for these with the Octagon receiver at some point
Had a little play around with the l.n.b. and scalar position on the 3.m last night ... (l.n.b 2 mm back - scalar 2mm forward ) and doubled the channel count to 60 ... Locked a further 5 transponders ... without losing 3837 H 6500 ...
Too windy up here today for any tinkering ... difficult to hold a lock on any t.p,s
(also too many other jobs on the to do list currently)
Well done, it is surprising how a couple of mm can make such a difference. The Madani frequency is one that often sems to be hovering above and below a lock for me.
Stiil not even a sniff of your "troublesome" frequency of 3834H, SR6500 (Apna) 'ere down Saarf.
I got the two data transponders that are ACM to lock with a TBS 6903 card and EBS Pro, they are both still active today so might be regulars. I will scan again with an Octagon SF8008 to see if it picks them up but I cant remember locking them previously with the SF8008.
