- Jan 1, 2000
- Location
- North Nottinghamshire.
........................................................................................................................................................................................................................................................................................................................................................................ Time for a bit of servicing and a change of lnb on the L/R/H/V C-band rig whilst the weather is decent.
The home brew rotating polariser joint ball bearings needs a check & re-greasing.
There's not a lot of new stuff happening at the moment on the 4.5 - 4.8GHz section so the Norsat 8000RI Extended C- band 3.6 to 4.8GHz lnb is to be taken off and i'll fit a NJS 8486S 3.4GHz to 4.2GHz lnb and check out what's going on since i last looked around the 3.4GHz area for a change.
A touch of adaptation to the flange coupling required due to the NJS having different fixing arrangement which has been done and ready to re-fit on the polariser asap.
View attachment 138411View attachment 138412
This picture might help explain why there are only two fixing bolts to the lnb plus two side clips. All the other lnb threaded fixings were not accessible for one reason or another.
