Horizon HDSM USB - Latest Firmware and software
easymo3
1m motorised
York England
Possibly not
II use Lyngsat
I can send pat files I have depending on what sats you need. thanks
HI, many thanks for your reply. I only need astra 28.2e with with sky Q as well so i can align standard sky aswell as sky Q
I have A labgear 501 as well but the horizon is so much easier to use.
cityaerials
Installer with horizon meter support
Coventry
Latest hex list i have has a few Ast2 tps that all work i think
Please see some example tps but some may be outdated now but can be updated.
  • SatEditTPS.rar
  • SatMeterhexloader.zip
  • JulyUK.rar
reDaCted
Astra 28.2E, Dell OptiPlex
Ireland
Possibly not
II use Lyngsat
Hi. Thanks for getting back to me. Looking for Astra 28.2, Astra 19, Hotbird 13 and Sky Q mainly. Anything recent .pat files you have on those would be great! Thanks :cool:
easymo3
1m motorised
York England
Thank you so much for this, installed onto my meter, will test tomorrow to see which tps are working,
Thanks again
cityaerials
Coventry
Thanks again
Thanks, please let me know any that don't work
easymo3
1m motorised
York England
Tested today, all tp's on 28.2e are working fine apart from one on sky Q tp26 did not lock.
I also have A motorised dish, if I get the time I will check the other satellites.
cityaerials
Coventry
hi, Thanks for checking these. I see Tp26 is now H S2, so have changed to tp22
  • HDSM-SET-AUG22.rar
cityaerials
Coventry
i will go through and update these as find dead tps etc.
  • TPs.rar
easymo3
1m motorised
York England
Thanks, loaded your latest set, all working great.
I noticed on sky Q there are 5 horizontal and 1 vertical, is that deliberate?
cityaerials
Coventry
no should be 5 of each
cityaerials
Coventry
what meter version do you have?
I'm guessing older v2.5 and cutting of at 32 tps?
I can do a list with just 32 main ones on
easymo3
1m motorised
York England
Yes, I have the 2.5version, works great, I only need it for 28.2 really.
easymo3
1m motorised
York England
That would be great if can do A list with the 32 main ones on.
I am not sure how I would do it!
cityaerials
Coventry
  • HDSM-SET32.rar
easymo3
1m motorised
York England
Thanks, about perfect for what I want!
All sky Q work and lock
all 28.2e lock apart from tp26.
easymo3
1m motorised
York England
Many thanks for all your help, I will load the last one you posted in A day or so, you have brought my trusted meter back to life, they really are great meters for aligning dishes, just pick your satellite and wait for the lock!
I have the Labgear 501 as well but they are A little cumbersome but do the job as well, just easier with the horizon.
I use A Unhom datum 10 for terrestrial aerial alignment.
markalmond
awilsat
london
hi , can someone help, i have Horizon hd s2 but from today 3/8/22 the Turksat 42e tp has changed , tried to update the tp manually but no luck
Manikm909
Small'ish Dish Man
Kent, UK
