Advice Needed 16 east footprint vs reality
cwsat
Gibertini 85cm / Dragonsat 3000 motor / Inverto Black Ultra LNB
Midlands
I have gone through all of the screenshots on my phone of my meter and they're all DVB-S........
cwsat
Midlands
I have just tried 11347V 22000 DVB-S2, 11362H 22000 DVB-S2 and 11229V 22000 and all I get is 45% Strength 20% quality.............
Exactly like 16e......
You know what I am thinking now............I have wasted time trying to find a signal the meter was never going to get.
cwsat
Midlands
I think that model is DVB-S only? If so DVB-S2 transponders won't lock, a quick look on Lyngsat suggests most 16°E TPs are S2. 12699 H 9880 is listed as DVB-S, it's not as strong as others but I'm receiving it with the zone 2.
I am going to take a portable TV and my sat box out and do it the manual way.
I owe you a big thank you for spotting that. I was considering calling a professional out.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
LeBelge
Belguim
The best way is that one:
KKkg5qFK
cwsat
Midlands
KKkg5qFK
If that’s your dish farm I like how you have mounted that in a bucket.
If I can get a signal my next step will be working out how to mount it. The tripod mount is ready to collapse, the dish is a bit too heavy for it. I tried to mount a minidish to a paving slab a few years back, it didn’t go well.
I set my old motorised system up using a TV out in the garden. Sometimes meters can get complicated.
cwsat
Midlands
Well, thank you so much @ozumo
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Great result :)
Adam792
Cheltenham
Nice to see a good end result! :)
cwsat
Midlands
I reckon I can squeeze a bit more quality out of that as I literally nudged the dish from Astra 1, moved the LNB a bit, adjusted the elevation and tightened it up.
The next thing is mounting it safely. It will take off in the wind on the camping tripod.
I have attempted to mount a patio mount to a paving slab in the past and it didn't go particularly well! I think the holes were too big and to counteract it, I tried to concrete in the coach bolts which didn't set.
Is there a certain coach bolt I need? I have a spare 600x600 slab.
I use M8 coach screws with a plastic plug. IIRC the hole was 10mm diameter - the plug or its packaging will state the correct size drill.
Adam792
Cheltenham
I've used M8 coach screws too, with some bog standard grey 10mm wall plugs.
I used to have a couple of patio mounts each attached to a couple of those solid grey breeze blocks where I used to live using them. They sat in the garden with no problem at all for the four years I was there. Each had an 80cm dish on it.
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Satlink WS6906.
Have one. They’re useless. You can’t read the screen properly in daylight and they only support DVBS not DVBS2.
As suggested hook everything up to a proper receiver and get a mate to help you position the dish for 16e.
cwsat
Midlands
Yeah sending it back. Not worth a penny more than £30.
cwsat
Midlands
I have ordered a galvanised 1m patio mount.
As soon as it comes i'll set about mounting it.
