zorrin
Specialised contributor
- CM 120 Ku 52°E to 45°O
CM 120 Ku 50°E to 45°O
CM 120 Ku SDR 25.8°E
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
GTMedia V8 Nova, V8X, V8 UHD 4K, V9 Prime
Edision Piccollo
- france
Hello,
I found 2 UHF antennas and I would like to couple them.
What type of coupler should I use ?
To fix them together on a horizontal tube, I decided to move the fixing from the back to the center of the antennas.
The weight would be better distributed between the front and the rear.
In this photo the vertical tube passes through the center of the antenna.
Do you think this is blocking reception?
