Terryl
- Apr 14, 2011
- Age
- 82
Custom built PC
- Deep in the Boonies in the central Sierra Nevada mountains of California.
Hi peeps....Well I have customer with a funny problem in an HP Lenovo ThinkCenter M92
It has a start up problem, it will power cycle on and off on and off till the AC power plug is pulled, try and restart it and it will do the same.
I have tested the power supply, changed RAM, changed the hard drive (after cloning it) and even the DVD player, they test fine in another system so they are all OK.
The only way to start it up and get it to boot is to first remove one of the RAM sticks, (weird) then power it up, it then will boot fine...But...Till you power it down and restart it, it then goes back into the power up/down cycle problem.. Pull the power cord and re-install the RAM stick it will then boot just fine, until the next power down...Then the problem comes back.
I'm beating my head against the wall on this one kids.....
