Home made diseqc positioner
dreambox1959
46.3N-4.3E-FRANCE
france
Is smps power supply going to be just as reliable as the torroid transformer one?
hard to say ! but the power supply costs 10 to 15 euros and it is regulated, the transformer 35euros + diode bridge + capacitor .........
femi
Austria
Irte 2.4m (C-Ku-band), Laminas 1.8m (Ka-Ku-C-band), a lot of other small dishes, terrestrical antennas and receivers
Lower Austria
Ich denke schon, werde auch für das nächste Steuergerät (für den Egis) wieder die Serie verwenden, die ich schon jetzt nutze. Der Unterschied liegt dann nur in der benötigten Spannung von 24V statt der 36V.
Nachdem es Einzelanfertigungen sind, wird es JP egal sein, was er dir einbaut, solange du die Kosten trägst.
Allerdings lese ich auch Beiträge, wo Leute schon in Schockzustand verfallen, wenn es um 10 € Versandkosten geht. Da muss man JP verstehen die Fertigung sehr günstig machen zu können.
I think so, I'll use the series I'm already using for the next control unit (for the Egis). The only difference then is the required voltage of 24V instead of 36V.
Since they're one-offs, JP won't care what he puts in you as long as you pay the cost.
However, I also read posts where people fall into shock when it comes to 10 € shipping costs. You have to understand JP to be able to make the production very cheap.
femi
Austria
Lower Austria
Can anybody say me is the serial TTL cable 3,3 Volts or 5,0 Volts?
dreambox1959
46.3N-4.3E-FRANCE
france
by definition, TTL technology is 5V but often the circuits in 3.3V are functional in 5V (to be checked in datasheet)
FEMI what cable did you find in 3.3V??
on aliexpress there is many products USB to TTL with selectable voltages 3.3/5v even 1.8/2.5V but for my positioner we need 5V because of microprocessor inside (89s52).
teltras
Channel Master 1.2mts superjack 18´´
Famaval 135PM Aluminium offset superjack 18´´
Famaval 1.0mts with diseqc motor Digipower SG-2100A
Andrew/Channel Master 1.2m with Jaeger SMR1224
Receivers:
Gigablue Quad UHD
Gigablue Trio 4K
KIII pro
Dm800HD
Portugal
Nice positioner you built.
dreambox1959
46.3N-4.3E-FRANCE
france
I found a funny bug on my positioner:
I bought several remotes from amazon (designed for SRT7004 an old satellite receiver)
Cardiff discovers this problem:
the on/off key gives another code between these two models of SRT7004 the code for on/off is on FAV touch!!!!
dreambox1959
46.3N-4.3E-FRANCE
france
I made corrections to my program for the positioner:
-I added the change of polarization of the skew with the remote control (when we are not connected in Diseqc).
- I changed the basic display with AZ and EL at the same time.
- various small bugs.
pitussat
dishes: CM 3m SMC,-Prodelin 3m SMC old version ,CM 1,80m SMC, Fibo 1,2m, Wavefrontier T90
receivers;>30 different types.+ TBS5925/6925 ETC
belluno, Italy
i have bought 5 printed-board in china , it s remain only one i can launch a new order !
who wants a pack ?
components are very common !
i give you one programmed µp 89s52 , relays , but you have to find and build it all !!!
here is my device :
the other pictures in another post are the Cardiff's device.
i'm interested in this project, i ìd like to buy as a kit
dreambox1959
46.3N-4.3E-FRANCE
france
On my polar frames I always put the actuator on the right, but Italian colleagues and surely others in the East put it on the left.
I thought of putting a parameter to define this case:
I want the azimuth counter to be at 0 when actuator is retracted and of course to drive the dish to the west when the west button is pressed (Blue), whatever the position of the jack.
also for the elevation I want the elevation counter to count from 0 when actuator is retracted and the jack to come out when the green button = UP is pressed.
of course the azimuth counter index will vary towards the west for the left mounting, and vary towards the east for the right mounting.
Great to see improvements of this awesome positioner!
ASC1 - eat your heart out.
Seconded - if and when my RC2000 goes belly up the JPC positioner will certainly be a contender for me if still available
dreambox1959
46.3N-4.3E-FRANCE
france
to respond to a request from FEMI, I developed a particular management of the cylinder movements: to compensate for the mechanical play of the mount, FEMI wants the mount to always go to its destination from the right, ex: - if we are on 19° and want to go to 13°, we will go to 10° and then come back to 13°. -on the other hand if we are on 10°e and we want to go to 19°e, we go there directly. -I did a test for cylinder positioned on the right, if the cylinder is on the left, the device will have to be reversed.
Um einer Anfrage von FEMI zu entsprechen, habe ich ein spezielles Management der Zylinderbewegungen entwickelt: Um das mechanische Spiel der Halterung auszugleichen, möchte FEMI, dass die Halterung immer von rechts an ihr Ziel geht, z. - Wenn wir auf 19° sind und auf 13° gehen wollen, gehen wir auf 10° und kommen dann auf 13° zurück. - auf der anderen Seite, wenn wir auf 10° sind und auf 19° gehen wollen, gehen wir direkt dorthin. - Ich habe einen Test für einen rechts positionierten Zylinder durchgeführt, wenn der Zylinder links ist, muss das Gerät umgekehrt werden.
dreambox1959
46.3N-4.3E-FRANCE
france
In my adaptation of my positioner for the EGIS motor there is a case that I had not completely foreseen:
-it is a prime focus antenna, there is necessarily a mechanical polarotor or equivalent.
Several users have dual-band, single-polarisation LNBs with LO switching via 14/18V (there are also 22k LNBs but they don't want to throw away their current expensive LNBs).
-I found a simple solution: configure the enigma2 receiver with a universal head (14/18v = polar, 22khz = band), my posi intercepts the two informations and uses the 14/18v to manage the H/V polarity and the presence of the 22khz to change the power value of the old standard lnb.
-Luckily both information are already retrieved by the current DISEQC setup and the 14/18v command for the old head is very simple to add.
Among the users there is also an Italian friend who is in this case on a prime focus on polar mount .
-with this addition I should be able to answer all cases of configurations
dreambox1959
46.3N-4.3E-FRANCE
france
Since the beginning of the creation of my positioner I have drawn 4 versions of motherboard, 3 types of keyboard, 2 models of LCD displays.
It was starting to be complicated to make modifications and then compile all these versions!
I also added some specific additions for Captain Jack, FEMI, etc.
I have reorganized my files with the use of assembly directives to have the most common pieces.
I also made a version for EGIS engine.
In a few days I will send an updated version to all.
I have no more contact with :
-Joolz
-danny10
-satfaca
if you are still interested in an update contact me.
FEMI and Aal41 I am working on the EGIS model and will contact you soon.
Seit Beginn der Erstellung meines Stellungsreglers habe ich 4 Versionen der Hauptplatine, 3 Tastaturtypen und 2 LCD-Display-Modelle gezeichnet.
Es wurde immer komplizierter, die Änderungen vorzunehmen und dann alle Versionen zu kompilieren!
Dazu kamen noch spezielle Ergänzungen für Captain Jack, FEMI usw.
Ich habe meine Dateien mithilfe von Assembly-Direktiven reorganisiert, um möglichst viele gemeinsame Teile zu haben.
Außerdem mache ich eine Version für EGIS-Motoren.
In ein paar Tagen werde ich eine aktualisierte Version an alle schicken.
Ich habe keinen Kontakt mehr mit :
-Joolz
-danny10
-satfaca
Wenn Sie immer noch an einem Update interessiert sind, kontaktieren Sie mich bitte.
FEMI und Aal41 Ich arbeite mit dem EGIS-Modell und werde mich bald bei Ihnen melden.
yoghy67
Prodelin 180 - actuator 36 inch - zgemma h7
Italy - La Spezia
mon positionneur peut gerer plusieurs configurations materielles differentes :
-1 une monture polaire avec 2 actuators AZ et EL .
-2 la meme chose avec un polarotor mecanique .
-3 meme chose mais avec le lnb changeur de TRUST (moteur diseqc 1.2)
-4 modele special Stanislav Grech : 2 actuators azimut + un moteur pour un changeur LNB avec actuator classique.
le contenu de la memoire EEPROM est organisé pour convenir a tous les modeles , mais certaines données ne sont pas utiles
pour chaque modéle : la position LNB à l adresse $00D0 ne convient que pour le modele 4.
Pour le modele 3 (le plus répandu) le 'JPCposi' envoi seulement une commande Diseqc 1.2 contenant un numero de sat de 0 à 16 ,
la position réelle du lnb changeur est memorisé dans le boitier du moteur lui meme.
Mon programme peut faire deplacer ce moteur et memoriser une position en face d un numero de 1 à 16 mais cette valeur est dans le moteur du changeur.
Chaque valeur (1 à 16) correspond à une tete LNB et n a pas à etre defini à chaque sat mais globalement.
Mon programme dialposi 7G permet de gerer ce fichier d EEPROM , j ai retiré les données destiné au modele 4.
Pour franck (FEMI):
sur le forum
Digital TV and Smart Tech Support Forum
L ami CARDIFF utilise mon positionneur avec un lnb changeur de TRUST , vous pouvez le questionner sur son maniement.
JP
My positioner can manage several different material configurations:
-1 A polar frame with 2 AZ and EL ACTUATORS.
-2 The same thing with a mechanical polarotor.
-3 same thing but with the LNB Trust changer (Diseqc 1.2 engine)
-4 Special Model Stanislav Grech: 2 Azimut Actuators + an engine for an LNB changer with classic Actuator.
The content of the EEPROM memory is organized to suit all models, but some data is not useful
For each model: the LNB position at the address $ 00D0 is only suitable for model 4.
For Model 3 (the most widespread) the 'JPCPOSI' sent only a DISEQC 1.2 command containing a SAT number from 0 to 16,
The real position of the changer LNB is recorded in the engine box even.
My program can have this engine move and use a position in front of a number of 1 to 16 but this value is in the changer engine.
Each value (1 to 16) corresponds to an LNB head and does not have to be defined with each SAT but overall.
My Dialposi 7G program allows you to manage this EEPROM file, I removed the data intended for model 4.
For Franck (FEMI):
on the forum
The friend Cardiff uses my positioner with an LNB Trust changer, you can question him about his handling.
Mein Positionierer kann verschiedene Materialkonfigurationen verwalten:
-1 Ein polarer Rahmen mit 2 AZ- und El -Aktuatoren.
-2 dasselbe mit einem mechanischen Polarotor.
-3 Gleiches Ding, aber mit dem LNB Trust Changer (Disseqc 1.2 Motor)
-4 Spezialmodell Stanislav Grech: 2 Azimutaktuatoren + Ein Motor für einen LNB -Wechsler mit klassischem Aktuator.
Der Inhalt des EEPROM -Speichers ist für alle Modelle organisiert, aber einige Daten sind nicht nützlich
Für jedes Modell: Die LNB -Position an der Adresse $ 00D0 ist nur für Modell 4 geeignet.
Für Modell 3 (die am weitesten verbreitete) sandte der 'JPCPosi' nur einen Befehl krank 1.2, der eine SAT -Nummer von 0 bis 16 enthielt.
Die eigentliche Position des Wechsler -LNB wird sogar im Motorbox aufgezeichnet.
Mein Programm kann diesen Motor bewegen und eine Position vor einer Anzahl von 1 bis 16 verwenden, aber dieser Wert befindet sich im Wechslermotor.
Jeder Wert (1 bis 16) entspricht einem LNB -Kopf und muss nicht mit jedem SAT definiert werden, sondern insgesamt.
Mit meinem Dialposi 7G -Programm können Sie diese EEPROM -Datei verwalten. Ich habe die für Modell 4 vorgesehenen Daten entfernt.
Für Franck (Femi):
im Forum
Der Freund Cardiff benutzt meinen Positionierer mit einem LNB Trust Changer. Sie können ihn nach seinem Umgang befragen.
@dreambox1959
I‘m interested to your positioner. Can you write me in private or my email **removed** thanks a lot.
Mod note - please don't post your email address on the forum
