Flysat accessing the site
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Try a different device to access Flysat. Just did a ping on their server and flysat.com is working fine. Just click this link to check yourself Home - FlySat Satellite Chart
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
Works fine here SW UK.
4wd
Getting the picture
5 W, 9-13-19-28 E
Well, today it's timing out here (from N). Worked the other day.
Still working here
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Is there much difference with Lyngsat?
Flysat tends to get updated quicker and more often, though that isn't much use if people can't access it :/
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
It seems to be a problem if you use cloudfare DNS. On my mobile i can access the page, on wifi using cloudfare DNS not. Are they blocking something in Turkey ?
rodscha
I got it back on tuesday..must be their filter ... works fine now!
Flysat seems to be permanently unavailable here now. Anyone getting into it?
4wd
Getting the picture
5 W, 9-13-19-28 E
Works here, Norway > French mobile (hotspot) > Turkey and all the way back, 1 sec.
Only works occasionally here.
edit: Forced an IP change and now it's working :confused
Satspot
1.2m Triax dish
Ireland
You’re using Firefox. Have you updated it recently. If so did you check Firewall rules in case they were defaulted. Are you using an adblocker. Are you operating behind a VPN by any chance.
I have the latest Firefox with uBlock Origin and Flysat causes me no issues ...... Of your suggestions, that leaves only VPN for @Analoguesat to eliminate.
Satspot
1.2m Triax dish
Ireland
There’s plenty more to be checked yet. I was just suggesting areas which could be investigated.
He hasn’t confirmed if he’s actually running the latest version of Firefox and what OS it’s running on. His public IP address could well be whitelisted on the Flysat site so using an alternative AP, device and/or browser would help eliminate possible causes.
The normal troubleshooting checklist as follows
  1. Restart your internet connection.
  2. Disable your firewall and antivirus.
  3. Clear your browser cache.
  4. Flush your DNS cache.
  5. Change your DNS servers.
Suffice to say there’s no issue with the flysat.com website at the moment.
I have to refresh the page a few times before it (slowly) loads. Haven't investigated further...
4wd
Getting the picture
5 W, 9-13-19-28 E
...and today, timing out...
Their host must have some serious problems.
