BBC ITV etc phasing out SD services on satellite in 2023
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
As I can't now see any BBC HD channels I'm going to be investigating horn antennas.
That's not going to work. It would have to be 54 metres long to beat a 1.8 dish!
dvdfilm
1.5m dish
spain
Probably not in the medium term, but if the launch of this happens before the new Bilsdale transmitter is in service, it's likely to carry BBC One North East & Cumbria HD at first (like it does in SD at the moment). ITV HD may also switch to the North East version for the same time.
But why would they put back the Red screen on Satback in the medium term? If on Freeview every region will have local news in HD, what sense would a Red screen have on Satback?
Adam792
Cheltenham
For the reasons stated by @Fisty McB .
It's not a regular feed, it's a back-up for terrestrial transmitters across the whole UK. There's only room for one version of BBC One HD, which they can change to whatever version they want depending on what transmitters need to use it.
dvdfilm
1.5m dish
spain
I did some calculations and I'm surprised they didn't find the space to keep a single network SD version of BBC One and Two.
In fact they currently have 4 transponders with SD channels, that could carry around 20 HD channels while they just need 15 channels, so the space would be there to leave a SD version of One and Two.
There'll be an SD version of BBC One & Two until at least 21st March 2024. After that I guess it depends on the size of any uproar like there was when they wanted to close the non-connected red button text service.
dvdfilm
1.5m dish
spain
This confirms my calculations were right, there Is enough space, it's surprising how they will justify cutting off services to licence fee payers who have SD equipment
Fisty McB
See my signature...
County Tyrone, N. Ireland
If money was no object, I'm sure the BBC would have no reason not to continue current SD services for the foreseeable future and simply rent out additional capacity from SES at 28E (there's a good bit going spare up there ATM).
However, money is an object and the BBC are currently in the process of making savings. Two English regions (Cambridge aka East (West) & Oxford) are closing down in the next few weeks with Cambridge merging into a single East region, can't remember where Oxford is going to merge into (sorry!)
I'm only guessing here, but there might also be an issue with the satellite uplinking/playout system for SD that is reaching nearly or at end-of-life.
At present, all BBC services at 28E (with the exception of the BBC Two NI HD test service) is spread across six transponders as follows (those with an asterik beside them have a HD simulcast) with BBC Three & CBBC plus BBC Four & CBeebies counting as one stream each as they timeshare...
BBC One English Regions
Channel Isles
East (East)
East (West)
East Yorkshire & Lincolnshire
London
North West
Oxford
South
South East
South West
West
West Midlands
Yorkshire & North Midlands
BBC One "National" Regions
England (HD Only)*
Northern Ireland*
Scotland*
Wales*
BBC Two Regions
England*
Northern Ireland
Wales*
BBC Scottish Channels
BBC Scotland*
BBC Alba
BBC UK-Wide Channels
BBC Three/CBBC*
BBC Four/CBeebies*
BBC News*
BBC Parliament
BBC Red Button
Total SD Services - 27
Total HD Services - 10
The plan for the BBC's satellite TV transmissions from April 2024 is to have all in HD as follows...
Channel Isles
East
London
North West
South
South East
South West
West
West Midlands
Northern Ireland
Scotland
Wales
BBC Two Regions
England
Northern Ireland
Wales
BBC Scotland
BBC Alba
BBC Three/CBBC
BBC Four/CBeebies
BBC News
BBC Parliament
BBC Red Button
Total HD Services - 25
The above figures doesn't include the radio services already broadcast, though these are largely inconsequential in the greater scheme of things.
At present the BBC uses two DVB-S2 transponders for 10 HD streams, 5 per transponder. If it were to stick to this from April 2024, they would only require five transponders instead of the six presently in use.
Alternatively they may be looking at what ITV presently do with six HD services per DVB-S2 transponder and try their hand at that. They could comfortably fit six into three transponders, but a fourth would need to be measured to carry seven - a possibility here would be to chance putting in services here that aren't normally "bitrate intensive" and could chance their arm at certainly slipping BBC Parliament in here as well as BBC News. Radio services could then be spread over the other three transponders.
From the above calculations, I'd reckon that one motivation for the HD upgrade programme is to both save on transponder rental costs and end duplication of services in SD & HD. While the BBC could retain six transponders in a post April 2024 transmission system, there is easily scope for them to reduce that, wherever it may reduced to five or even four will depend on internal BBC decision making.
And without knowing the more technical details as to what will happen in Q1 2023, what looks almost certain to happen is that three of the current DVB-S transponders will in phases be turned over to DVB-S2 transmission, with one DVB-S transponder remaining in place until April 2024. This will require some reshuffling of SD (and probably current HD) services during this time to allow changes to be made until by April one DVB-S transponder is left carrying the following...
BBC One (UK)
BBC Two (UK)
BBC Three/CBBC
BBC Four/CBeebies
BBC News
BBC Parliament
BBC Scotland
BBC Alba
BBC Red Button
...plus the BBC Radio stations on satellite.
The only way to continue broadcasting a BBC One or Two SD service compatible in its present form is on a DVB-S transponder - the BBC I'd be at least 99% certain will be accommodating their HD only services on DVB-S2 transponders, so there's no real space left available for such an event.
Just to finish, I'm going to stick my neck out here and say that the April 2024 date - or some time around it - will end up being the "sunset" date for DVB-S MPEG2 SD broadcasts aimed at the UK, not just for the BBC but also for ITV, Channel 4, Channel 5 & Sky, with all future transmissions from these broadcasters at least going over to DVB-S2 MPEG4, either in HD or SD.
BBC One HD rollout / SD removal dates:
RegionSkyFreesat
Channel Islands14/02/202313/02/2023
East31/01/202330/01/2023
East Midlands31/01/202330/01/2023
East Yorkshire and Lincs07/02/202306/02/2023
London14/02/202313/02/2023
North East & Cumbria21/02/202320/02/2023
North West (inc. Isle of Man)21/02/202320/02/2023
Northern Ireland (SD removal)24/01/202323/01/2023
Scotland (SD removal)21/02/202320/02/2023
South24/01/202323/01/2023
South East23/02/202322/02/2023
South West14/02/202313/02/2023
Wales (SD removal)07/02/202306/02/2023
West Midlands07/02/202306/02/2023
Yorkshire21/02/202320/02/2023
BBC Alba07/02/202306/02/2023
BBC RB114/02/202313/02/2023
BBC Parliament21/02/202320/02/2023
woborny
And on looking on Freesat, when your region goes HD you may not have access to the "BBC One SD" version at all - could be an issues for those on the fringe with wrong size dishes. Just checked on mine set to BBC One South, which went HD on 101 this lunchtime, and nowhere on the EPG is there a BBC one SD using 12442...
mikeisyou
Feed Hunter
England
BBC One HD rollout dates:
RegionSkyFreesat
Northern Ireland24/01/202323/01/2023
Scotland21/02/202320/02/2023
Wales07/02/202306/02/2023
In Northern Ireland, Scotland and Wales on these dates given will be the removal of the SD variants of BBC One and BBC Two. In Scotland it will just be BBC One Scotland SD closing because Scotland no longer has a BBC Two variant and uses the same version as England.
curly wurly
180cm dish - Pace 430N - Inverto Black Ultra LNB
Northern Tuscany, near Viareggio, Italy
Does anyone know if the BBC News channel has been taken off SD yet ? I'm unable to receive it anymore.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
SD is now on 12422 H 27500 2/3 :Y
curly wurly
Thanks lovelyperson - much obliged.
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
The signal of the frequency 12,422 H is somewhat weaker.
Nalleman
Motala Sweden
Sweden
I'm getting it at around 10 dB here in southern parts of Sweden. No problem.
FEC 2/3 also means a bit bigger margin in bad weather.
Butacas
It is also received here, throughout the day. With better signal in the morning, in all the frequencies of the beam of the United Kingdom.
You have a year to enjoy 12422H It will shut down early 2024.. Then you will have to hope you can get the harder to receive dvb-s2 8psk transmissions.
Nalleman
Motala Sweden
Sweden
Fortunatley are the other transponders used by BBC stronger at my place (10,5 - 12,5 dB ) and I have no problem getting them i DVB-S2 8psk. If they decide to use another FEC let's say 8/9 or 9/10 worst case it might be a harder nut to crack.
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
12168V is the only BBC HD transponder I'm getting at this time. Will it be going too?
