where can i get a STP5N90 for a pace by prime
astra 1D
digital setup on astra and BSB British satellite broadcasting receiver not setup and a analog satellite box not setup
UK central
the power supply has failed on my pace by prime analog satellite receiver
the part i think i need is STP5N90 dose any one know were i can get one
thanks
Ebay is probably about your only hope. The vast majority of those receivers will ahve been scrapped over a decade ago.
astra 1D
UK central
yes i have bean looking on ebay but all it comes up with is DURACELL battery.
https://www.donberg.co.uk/catalogue/stp_5n90.html
astra 1D
UK central
that is but the web site looks a bit sketchy have you use it before
astra 1D
UK central
ok i will look in to it
but the receiver only cost my 1£
thanks
Can you post a picture of the PSU and one of the connector ?
I have boards here that may be a close match though it may also highlight components that could bring the receiver alive if replaced.
It appears they can also be sourced from Aliexpress.
https://m.aliexpress.com/item/32280084880.html
astra 1D
UK central
i am not sure if it will work i will look in to it
astra 1D
UK central
153BDCB7-4698-40DA-8CA5-9AA7C83600D3.jpegHere’s the picture of the psu
Looks like the Primary side of most simple Switched Mode Power Supplies and I assume that the required transistor fits on the board in the position marked "U1" - OTOH, doesn't really give any info that would help in choosing a replacement transistor as that would depend on the values of the components around it. And, of course, C3 & C4 should also be replaced as a matter of course (by High temp 105C components!) as well as VDR1.
NB: if not already done, you should check the Primary windings on T2, and whether D1 to D6 D8 are still OK (may be short-circuit). The diodes can be replaced (by same types, especially D5/D6 D7/D8 which may be High Speed types!) but if T2 is damaged then the PSU is probably unrepairable as it was probably a bespoke component that is unavailable (unless you could find another working receiver of the same/similar type!)
astra 1D
UK central
Thanks for the help
I will check T2 and see if that is to blame
astra 1D
UK central
does anyone know where i can get the manual and service manual for this receiver
Needs the exact model number for anyone to be able to help you with that !
astra 1D
UK central
pace mss1000 i think
