Just Sharing This Briefly 2 EU beam muxes on Intelsat 37e 18.0° W
Dggrr
SF8008, TD88, Gibertini 1.25, T-55
SE
From an Enigma2 blindscan with a 1.2m Gibertini in far west Herts:
# cat blindscan_18W_13-01-2023_*
<?xml version="1.0" encoding="iso-8859-1"?>
File created on Friday, 13 of January 2023, 14:14:49
using sf8008t receiver running Enigma2 image, version 7.1,
build 20230111, with the blindscan plugin
Search parameters:
Tuner A: Si2166D (DVB-S2X)
Satellite: 18.0W C-band Intelsat 37e
Start frequency: 12600MHz
Stop frequency: 12750MHz
Polarization: vertical and horizontal
Lower symbol rate: 1000
Upper symbol rate: 40000
Only save unknown tranponders: yes
Filter out adjacent satellites: up to 3 degrees
Scan duration: 97 seconds
<satellites>
<sat name="18.0W C-band Intelsat 37e" flags="0" position="3419">
<transponder frequency="12639000" symbol_rate="7000000" polarization="1" fec_inner="0" system="0" modulation="1" />
<transponder frequency="12643000" symbol_rate="27500000" polarization="0" fec_inner="0" system="0" modulation="1" />
<transponder frequency="12666000" symbol_rate="1660000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12684000" symbol_rate="27500000" polarization="1" fec_inner="0" system="0" modulation="1" />
</sat>
</satellites>
21 mostly Tunisian channels but back to recent normal a little bit later:
File created on Friday, 13 of January 2023, 15:26:18
Search parameters:
Start frequency: 10700MHz
Scan duration: 294 seconds
<satellites>
<transponder frequency="11039000" symbol_rate="39956000" polarization="1" fec_inner="0" system="0" modulation="1" />
<transponder frequency="12731000" symbol_rate="25728000" polarization="1" fec_inner="0" system="0" modulation="1" />
</sat>
</satellites>
Not sure which image you used? Maybe openatv?
And which plugin you just installed? Thanks.
