- Mar 29, 2004
- UK
Six channel golf mux in NS3 @7E
Are you getting the video to play smoothly on the FTA channels?
For some reason I seem to get stop/start of the video on this specific mux, it will play for three or four seconds then judder then play again.
The same artefact is not present on other NS3 frequencies so I think there is something going on here that my equipment is not optimised for?
I have tested it in VLC from the ASI capture card via TransEdit and also routed it through an Ericsson RX8200, same artefact both times.
It might be the LNB, I am using a DRO LNB rather than a PLL LNB and sometimes these higher FEC's seem more stable with PLL.
Could you please tell me what LNB you are using to capture the signal?
