Tbs tuner and crazyscan - probably not a pc card issue
StreamReaderEx for BDA Tuners v. 1.2.4.137 from 15.10.2022
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
Happy New Year !
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
big DMA buffer not allow receive low bitrate radio channels.
Joolz
1m Astro 55°E - 63°W
StreamReaderEx BDA v.1.2.4.141 from 22.01.2023
Many thanks,@CrazyCat :)
Thanks for the update
With new version Crazyscan at 500ks. not able to lock below this but get as low as 166Ks on EBSpro - do I need to change a setting??
EBSpro 250Ks
EBSpro 166Ks
EnoSat
enosat.euweb.cz
Slovakia
try set Mininal Symbol Rate in CS on 100
Joolz
Lowest Rate on the pull down box is 1000.
I changed the field to 100 but still no success.
EnoSat
enosat.euweb.cz
Slovakia
streamreader.dll is the same in both programs?
Joolz
StreamReaderEx for BDA Tuners-v.1.2.4.143 from 2.02.2023_update
StreamReaderEx for BDA Tuners-v.1.2.4.143, now from 23.03.2023
StreamReaderEx for BDA Tuners-v.1.2.4.146 from 19.04.2023
Updated Montage M88RS6060 SDK.
Maybe TBS 5930 and 5530 BLScan2() fixed ?
In the meantime, StreamReader version 1.2.4.148 was released at 22:49
StreamReaderEx for BDA Tuners-v.1.2.4.148 from 22.04.2023 22:04
Same version but modified. I'm unsure, but it looks like a tbs5930 blind scan issue.
-carrier search algo some changed in PLS code detection
MCelliotG
Thessaloniki, Greece
Has this eventually fixed the erroneous dB readings on this tuner? It only measured increments by 1dB (12.0, 13.0, 14.0 etc)!
This version's first effect is correctly displaying the FEC for Montage M88RS6060 cards.
Here is what the previous version displayed compared to 1.2.4.146 for the S2X muxes. It was tested with 6902se.
Meanwhile, version 1.2.4.148 has been released.
