Any idea on the make of it?The LNBs look to be 40mm so would assume the holder is too. Ask the seller for the dimensions of the dish, it may not be much bigger than what you've already got.
It is an olde Lenson Heath reflector.What dish is this?
It's not far from me, considering going and getting it, just concerned how heavy it will be and if it's got a 40mm collar.
Second-hand Items for Sale in the UK | Gumtree
Find used and second-hand items for sale in the UK on Gumtree, from clothes and electricals to furniture, tickets and more.www.gumtree.com
Were these the ones that needed an inch off the boom arm to maximise signal?It is an olde Lenson Heath reflector.
The indifferent boom arm length was an issue with maximising signals during installation, with corrosion at the bend shortening life expectancy to about three/five years in the field.
Old Megasat Irte?1.8m dish over on Ebay £20 start
If the LH is no good the backplate looks like it could be used to mount a small Channel Master with a little bodging.Any idea on the make of it?
Gonna pass on the Lenson and hold out for a lighter alu dish.If the LH is no good the backplate looks like it could be used to mount a small Channel Master with a little bodging.
Blends in with its surroundings surprisingly well.Old Megasat Irte?1.8m dish over on Ebay £20 start
New price, inflation adjusted (1990 to 2022): £871.47 + VAT without standOld Megasat Irte?1.8m dish over on Ebay £20 start
top two panels to the left are really bent.Blends in with its surroundings surprisingly well.
So the boom arm did not need altering for you?I had one of these dishes on the 90's, they were a light dish..I even managed to just about get Thor 1 on it with a Cambridge modified LNB. The back plate also enabled the dish to be attached directly to a Jaeger 128, much better that any Diseqc motor.
Never had a issue with focus, although CH is right about the corrosion on the bend of the boom arm, a bit of waxoyl sorts that out..
No, I never cut it or bent it..I haven't got the dish now, but assume it would have been over a metre in height..So the boom arm did not need altering for you?
Are they exactly a 1m high and wide?
At first glance, I thought it was an Alcoa!Old Megasat Irte?1.8m dish over on Ebay £20 start
It could still be an Alcoa as the polar mount design is not the Irte style one. Maybe someone has the 2.4m extension panels in a junk pile!At first glance, I thought it was an Alcoa!
The Gibby doesn't - to me, at least - look anything like the one listed, and so I'm confused as to why you suggested that??Gibby 125cm
Gibertini OP 125L satellite dish | eBay
Find many great new & used options and get the best deals for Gibertini OP 125L satellite dish at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
