- Jan 1, 2000
- Location
- North Nottinghamshire.
putting the nb with 5 G filter and then also inserting the separate 5 G filter you get a doubling of the filter value
however I must also say that if 5G ends at 3800 these products are useless because they filter at 3700
On a more reputable brand of a 5G Cband lnb the internal circuit design and suitably designed front ends are far more advanced than the cheaper Chinese offerings but are very expensive.
Have a full read of this document from Norsat re: 5G interference and suggested solutions.
