Free To Good Home Free stuff - LNBs
I have a bunch of stuff that I need rid of.
Ka-band LNB - came with the dish (below). No idea if it's any use. Untested.
Chaparral feed with polariser + waveguides + LNBs. None of this has been tested.
Ka band dish - but will work with anything. The Ka band LNB above fits directly onto that.
76mm stand. Seen better days but had been sandblasted a while back and powder coated with the white stuff.
The dish and the stand are going to the tip if there is no interested in the next couple of days. I'll hang on to the LNBs until someone takes them.
Everything is free to collect. I will post the LNB bits at your cost.
I will take the Ka LNB CJ. Be a post job though. Will PM you later.
Sorry Chris, the Ka LNB is already spoken for.
I do have another one, so send me a PM and I'll take some pictures.
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Zanima me chaparal v kompletu. Videl sem, da jih nekateri imajo, a do sedaj še nisem imel v rokah takega Lnb-ja.
All the LNB items are now spoken for.
Dish and stand going in the tip.
It would be good to know the bagger (and that of the Chaparral kit) for transparency and to avoid fallout.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I am not aware of Chaparral kit, but Ka set is travelling to Latvia :)
OK, all my stuff is gone now. Dish and stand in the tip, LNBs to members of the forum.
I'll likely find more stuff to give away as I am clearing the garage and the loft...
dreambox1959
46.3N-4.3E-FRANCE
france
i received a gift from Alex
does someone knows how is the dielectric shape to put inside this corotor ?
Give me a day and I'll pull the same one I have out of stores. (though I think it never had the circular bit for C band)
If you can provide the part number embossed on the side I can look through the archives.
Satfaca
Melmac (46N, 14.5E)
Melmac
You won't be able to fit in any apropriate plate into this model, it is a pure Corotor II+ for the linear reception. Used plastic support you can see doesn't allow retro fit.
Here are the images taken from the US forum of the dielectric versions:
Corotor II+ International
Corotor Tri-band
Trust
Nijmegen Netherlands
A polarpipe like AV-COM will do .
yang sat
13 Hotbird
OX3
Why would you convert a dual-polarization HV product into a single polarization and then mechanically switch between H and V?
Trust
What about LH / RH Circulair signals ?
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
What is your reception of circular polarization on 36E, with what size antenna if it passes through your place
